Old 21-06-09, 09:50 PM   #11
Default Re: Puncture Kit
These stop and go kits are meant to be good. That's what I have. And I got some extra air canisters
Old 22-06-09, 06:10 AM   #12
Kilted Ginger
tyre weld cans, crap, messy and do not work.
the type in the first link are good, do the jib but are a bit of a phaff, akward and messy. Also although you get 3 plugs there is only enough glue and air for one repair.
The other option string things are supposed to be good but very akward to use, i have no experience of these.
These are the dogs. very easy 100% effective, 30 seconds to use. I havent used in anger yet but seen them used and had a practice on an old tyre. doddle, cant recommend enough. Demonstration video.
HTH
Old 22-06-09, 07:34 AM   #13
petevtwin650
HTH
Ditto about Tyreweld type cans.
The glue and plug did work on KG's tyre but only because (a) he was strong enough to force the plug in and (b) because somebody squeezed the side wall and allowed the plug to go in.
That turn and go pack looks very good. If it works! But it only has 4 air canisters. The ones KG had barely inflated his 160 rear.
Old 22-06-09, 07:48 AM   #14
fizzwheel
fizzwheel's Avatar
I've used tyre weld twice
Once it was sucessful, ( small hole caused by a piece of flint ) the 2nd time not so, big slit in my back tyre caused by a piece of metal in the road. The hole was to big and the foam just blew straight out the of it when I tried to inflate the tyre.
I carry a rep and air kit under my seat now. I dont trust the tyre weld it only works in a small set of circumstances IMHO.
Old 22-06-09, 08:15 AM   #15
Stig
Sticky string of any variety works for me. I've used the plugs before and had them fail. I have even had the AA use them and have them fail. Never ever seen sticky string fail.
Old 22-06-09, 09:23 AM   #16
Dave20046
Dave20046's Avatar
I've just bought the stop and go kit Darren linked but from www.mandp.com using the online voucher code MP0609 which'll give you free postage(/£5 off) up until august.
enjoy
while I was there I also bought the £5 chain & closed shackle padlock http://www.mandp.co.uk/productinfo/5...r-Chain-Series Dunno what the quality'll be like (well I do it'll be shoite)but I can add it to the collection.
Old 22-06-09, 03:27 PM   #17
markmoto
a solution to the co2 canisters not putting much air in the tyre is to carry a double action mountain bike pump the one i carry is only about 8 inches long and goes under the seat, then after using the co2 canisters ive used the pump takes a while but gets the job done.
Old 22-06-09, 03:40 PM   #18
SoulKiss
SoulKiss's Avatar
Better to use the bike pump 1st then the cannisters - let the compressed air do the work....
Old 22-06-09, 05:11 PM   #19
mattSV
mattSV's Avatar
I was lucky when I used my puncture kit - pulled in to a Kwikfit in the ****ing rain, they took pity and let me get in out of the rain to do the repair & use their airline. I now always carry extra canisters with me though, just in case.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 24-06-09, 02:19 PM   #20
Spiderman
Where the hell am I?
Spiderman's Avatar
HTH
Not seen this type before, looks dead easy to use but how does it "seal" the hole if its a bit bigger than the screw part is i wonder? And what stops it working itself loose since there is no glue of any type holding it firmly in place i wonder?
Glad someone come up with such a simple solution tho
Puncture. maclovin Bikes - Talk & Issues 9 15-03-09 10:00 PM
Puncture or not? hob Bikes - Talk & Issues 1 06-02-09 10:34 PM
Oh ffs! puncture. lazymanc SV Talk, Tuning & Tweaking 15 02-10-08 12:11 PM
Puncture.....not so bad after all toonyank Bikes - Talk & Issues 7 07-07-07 11:20 PM
Puncture Stu Guildford Massive 4 06-01-07 10:52 PM
