Old 25-06-09, 10:30 AM   #11
warrenhewitt10
Default Re: Turn key...nothing happens
yeh mines a k3 too in the same colour as urs it seems i shall go have a poke at it now. Did urs ever switch off again once the engine was started cuz mine doesnt and i find that strange if its a connection problem....
Old 25-06-09, 10:36 AM   #12
simesb
Nope - just turn the key and nothing but once I had the ignition it was fine. If you do look at the green plug (it's the one that come from the ignition) it's much easier if you take the airbox off and have small hands.
Old 25-06-09, 10:05 PM   #13
Lucas
this has just happened to my curvy
got on bike, turn key to 'on' position, lights comes on ok, normal etc. clutch in and press the starter button, motor turns over, a few seconds later cuts off
lights on the panel is still on, so clutch in and start again, motor makes a little turn then everything cuts out!
key is still in 'on' position, but lights on panel are now gone, turned the key a few times still nothing, not a light, noise... i have no idea
i've checked the killswitch, sidestand position. all the fuss in the main fuss box are fine.
I'm now charging the battery, but I dont think its the problem.
Could it be the starter relay?
Edit: my bike near a Arson Arrack last week, could this be the cause? there are no surface damage to the bike, but could the heat cause some sort of interenal damage? but then again the bike get hot running normally anyway so I can't see it being the cuase.
cheers guys
Old 26-06-09, 04:49 AM   #14
embee
embee's Avatar
On the curvey, check the known wiring chafing points. If the wiring rubs through on something metal attached to the frame it can short out and blow fuses, or all sorts of intermittent running glitches can occur.
Check behind both riders seat fixing bolts (they are slightly too long and can hit the wiring harness which is conveniently routed immediately behind them). Also take off the pillion seat and check on the left side towards the rear where the wiring wraps round a frame bracket. There can be rubbing anywhere round the headstock when the steering is turned, so look carefully around there.
Check all fuses (battery compartment), including the main 35A one in the green relay behind the right side triangle.
Old 27-06-09, 03:41 AM   #15
Nicky S
Nicky S's Avatar
half 4 in the morning . . Just bin droped off by the lovley recovery man. My curvy has snuffed it l. . Pulled up to some lights and they go green so im off not for long both gauages go mad lose my lights and bike dies like i have run out of petrol. So pull over turn the key off then on and iv got everthing back go to start the bike and lose everthing again. So try this a few more times. .. Nothing so stick bike on stand and have a smoke turn the key still with bike on stand withoutme on it and everthing is back try starting it again same thing just dies. I shock the wirring near the headstock nothing killswitch fine and battery is ok i also have lots of fuel.
Any ideas ??????
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 27-06-09, 06:47 PM   #16
Nicky S
Nicky S's Avatar
Dw people fixed it. It was the battery terminals
Can I turn up? 454697819 2009 Annual Rideout 16 17-06-09 09:47 PM
02 SV needs new turn signals s3rv3nt SV Talk, Tuning & Tweaking 2 07-10-08 12:31 AM
Key wouldn't turn hedgehog SV Talk, Tuning & Tweaking 12 01-09-08 03:28 PM
Joke (my turn to try!) Filipe M. Idle Banter 7 25-08-06 05:12 PM
