Old 03-07-09, 10:07 AM   #11
Dave20046
Dave20046's Avatar
Default Re: Carby is louder than my Injected
It's the K+N filter letting you hear all the induction snort.
Try it with tank raisers and BMC RS filter, and remove the dampening foam from the bottom of the tank. THAT'S a snort! Can't hear the can above 6k...
Badger was saying with the tank risers the the induction snort was almost unbearable (in a pleasurable way I imagine). Does removing the foam help a lot chris?
Old 03-07-09, 10:08 AM   #12
It's not the crank on the K3's, they sometimes randomly spit their conrods. It is rare, but does happen.
Dropping it makes no odds, to give the crank and rods the same G forces that they experience at tickover, would probably squash the whole bike to the thickness of a bean tin...
Maybe pointy is different, curvy does not have much room in between top of airbox and tank. Removing the foam gives you another 1/4" of airflow, dunno how much power added?
Old 03-07-09, 10:10 AM   #13
GavinD
Its the exhaust noise not the induction thats so dramatically (jazz hands) different!
Old 03-07-09, 10:18 AM   #14
warrenhewitt10
i thot it was the K5 was the year that they brought all that stuff in..... (n yeh no wheelies ha)
Old 03-07-09, 10:20 AM   #15
GavinD
nope my K5 had none of it one - exhaust looks identical apart from the join is further forward on the front pipe.
Old 03-07-09, 10:42 AM   #16
Dave20046
Dave20046's Avatar
Ah sorry thoguht I read they had a weak crank. Con rods ain't too expensive right? Or does other damage occur when a conrod goes?
I was just thinking dropping it because it's put the force in the wrong place, I was thinking along the lines of why I got shouted at for using an impact driver on a crank once
Hmmm might experiment with removing the foam....
Old 03-07-09, 11:33 AM   #17
Con rods are about £500 for a pair of carillos, and the broken end tends to smash the engine cases to bits. so yeah moderately serious...
Old 03-07-09, 11:40 AM   #18
Holdup
I should know
On topic, isnt there a sort of mesh in the K3 > down pipe just about where you cut it? there was in mine till i smashed it out, that might silence it a bit.
Old 03-07-09, 05:26 PM   #19
Same in curvy. It's only round the outside of the pipe anyway so won't make much odds.
Old 03-07-09, 05:43 PM   #20
walkaboutandy
Its probably the cam that has caused it to be louder. Do you know what the difference (valve duration, lift, etc) is compared to a standard one?
Carby Minitwin 4 sale - SOLD Hell4leather For Sale - SV's and SV related items 2 11-11-08 11:13 PM
louder exhausts wow SV Talk, Tuning & Tweaking 9 31-07-08 08:18 PM
does oem can get louder with more mileage ? steveg SV Talk, Tuning & Tweaking 17 02-05-06 09:59 AM
Raceteched forks, Carby front wheel with discs Robw#70 For Sale - SV's and SV related items 0 16-12-05 06:56 PM
which is louder? alison_w Exhausts 5 12-10-04 08:55 AM
