Old 21-08-09, 06:39 PM   #11
warrenhewitt10
Default Re: making a cluck noise whilst reving
does the fuel level sensor still work? my friend has a curvy and part of his had broke off and was floating around in the tank. but if it was something loose inside the tank id expect more of a metallic noise rather than a clunk...
Old 21-08-09, 06:43 PM   #12
Could be the imfamous front suspension clunk, manifesting from the fuel tank
Old 21-08-09, 07:42 PM   #13
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
Originally Posted by redlavachips View Post
hi folks, just serviced the bike and can hear the noise comming from the fuel tank, i think there is something loose in there any thoughts?????
Does it only manifest when you're on the throttle? If so it's the injectors, perfectly normal
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 21-08-09, 09:14 PM   #14
is it while you are riding or while you are stationary or both?
Old 21-08-09, 10:07 PM   #15
redlavachips
it does whilst moving and stationary but louder when moving( vibrations) when i had the tankup today it wasnt making a noise and if i shake the tank it makes the noise
Old 21-08-09, 10:30 PM   #16
i think you have answered your own question... but its possible that the mounting bolts are loose or the fuel pump/parts are loose. only way to find out is empty tank of fuel and investigate.
Old 21-08-09, 10:36 PM   #17
redlavachips
yeah probably just seeing if any had the same problem , whats easiest way to empty the fuel tank or ill get a mechcanic to have a quick look.
anyway next question, whilst change the front spark plug i have sheared the radiator bottom bolt, any ideas or live with it
Old 22-08-09, 03:54 PM   #18
Drill and bolt right through the bracket.
Old 28-08-09, 03:59 PM   #19
redlavachips
hi all, found out wat the clucking noise was( apart from the chicken i was keeping under the pillion seat). it was the petrol tank breather or something as it was loose
ciao for now
bike cutting out while reving davepreston SV Talk, Tuning & Tweaking 10 09-01-09 01:10 PM
Stalling on Reving mbuk SV Talk, Tuning & Tweaking 8 02-06-08 11:56 PM
Dad, my van is making a funny noise when I do 80 timwilky Idle Banter 32 21-09-07 08:33 PM
Should my bike be making this noise? dmracing SV Talk, Tuning & Tweaking 6 13-03-06 03:57 PM
cut out when reving up K2 SV Talk, Tuning & Tweaking 3 02-05-05 07:41 PM
