Old 10-07-09, 12:10 PM   #11
drag
Default Re: Carb balancers and air boxes
They do need some wiggling, I normally take the air filter out and check that all the lips are on right. Else go round and give them a little assistance.
Good idea grinch, weird thing is i just lashed on the gagues there a few mins ago, she was a little out, all fixed now, and the air box popped back on relatively easy.
odd how things go i guess
Old 10-07-09, 12:13 PM   #12
Grinch
The last time I did it, I balanced the carbs with the airbox off so I could easily get to the adjuster screw and then tested it again with the airbox back on.
Old 10-07-09, 12:14 PM   #13
Grinch
Sometimes you get lucky, most times its a bit of trouble.
Old 10-07-09, 01:26 PM   #14
johnnyrod
johnnyrod's Avatar
The fluttering has two possible causes - you have crap gauges (if they have restrictor clamps in line with the hoses then this is probably the case, like these):
http://www.busters-accessories.co.uk...EVG2&kw=vacuum
or it's runnning lean. If it' is running lean, you need to upjet of course but if you take the appendix thing off the left side of the airbox and plug all the holes, you can get to the balance adjuster while the airbox is attached.
Old 10-07-09, 03:24 PM   #15
drag
Ya those are the balancers i have, they worked pretty ok when i adujusted the T connector, she's running a little rich on top end, but she's getting rejetted on sunday, hense the dry run with the balancers today
Old 10-07-09, 03:41 PM   #16
MattCollins
Don't know why you lot persist in fa*t ar*ing around with gauges...
First hit with google:
http://www.obairlann.net/reaper/moto...manometer.html
Old 10-07-09, 04:22 PM   #17
great for having in the workshop. but who wants to cart an 8 foot board around with them.. suppose you could cut it into sections and hinge it. but its not very bling
carbtune every time for me...
Old 10-07-09, 06:00 PM   #18
drag
Might splash the cash and buy a carbtune in a while, new tyre soon tho, as new front end is going on nxt week
Old 10-07-09, 08:01 PM   #19
Old Git
Old Git's Avatar
Im wiv u, made one similar only 1m tall, filled with oil, not used yet but should work fine.
Old Git is offline   Reply With Quote
Old 10-07-09, 09:21 PM   #20
dont think oil is good.. it tends to stick to the tube and you cant get a reading correctly, its also to slow..
water with dye in it..
Stopping in cycle boxes before red lights. jambo Soho Massive 27 17-05-09 01:44 PM
Carb balancers I could borrow? sam anon SV Talk, Tuning & Tweaking 3 21-11-08 06:49 AM
Boxes full of bits... Daimo For Sale - SV's and SV related items 4 29-01-08 01:46 PM
Top Boxes tricky Idle Banter 28 28-04-06 06:15 PM
top boxes benny SV Talk, Tuning & Tweaking 15 15-01-05 09:02 PM
