#11 | |
![]() Yes... I will need to make sure of that too. I've also got to pop the power valve motors off and make sure they are not seized, as the last time they where more jammed then a jammy thing. Got them working though and the made a satisfying 'Zitt, zitt...' noise. |
#12 | |
Lots of oil to think about... I think I was about 22 in that photo... |
#13 | |
Good luck Dan,
I'll defer to the above advice, but I for one would be with Shosha and suzsv650 and have the heads off to check I was happy with what was occuring. 2 stroke motors are much simpler to strip and rebuild than 4 strokes, and I'd want to know if the bores were scored or rusted before I set off down the raod. Quote:
Hope this helps Jambo
#14 |
Well its all something else to keep me busy along with the 700cc job on the SV. Not sure where I'm going to pull the time out to do all this work. Might have to take the engine with me to London so I can work on it, lol, good job stokers are small.
#15 |
Looks sweet, will be fun!
If it mixes itself I'd be tempted to leave it at that but I know a lot of people like to seal those up and mix it in the petrol tanks themselves. I thought you just wanted the basics to get it on the road quick but if you're doing it properly it probably is worth checking the barrel & pistons & changing the rings, never seen one of the engines but depending on its state you might want to swap the seals.
#16 |
Give the PowerValve a good clean too.
#17 | |
Trinity
![]() Stu |
#18 |
dont the kr1's have chromed barrels?
good advice as said above especially seals.. |
#19 |
No idea... never had the head off. I know the early models the c1 and c2 where prone to piston ring pegs coming loose in the bore. It was fixed in the c3 but I have a c2 so will need to check that.
#20 |
2 Stroke Help | DarrenSV650S | Bikes - Talk & Issues | 2 | 10-05-09 03:16 PM |
Stroking? Pleasurable? No that can't be right! | missyburd | Idle Banter | 4 | 12-04-09 11:37 PM |
I think I want a 500 2-stroke! | ThEGr33k | Bikes - Talk & Issues | 59 | 27-12-08 11:00 AM |
Ever used 2-stroke oil in your 4-stroke fuel?? | Blue_SV650S | Bikes - Talk & Issues | 3 | 19-08-06 07:22 PM |
2 Stroke HELP!! | Last Action Pimp | Bikes - Talk & Issues | 8 | 26-11-05 01:41 PM |
