Old 14-07-09, 10:21 PM   #11
lukemillar
Default Re: Car compression test
Originally Posted by embee View Post
If it's been breathing oil carryover due to random overfilling it could just be loads of deposit build-up on the backs of the inlet valves. Carbs also tend to exacerbate deposit build-up (compared to FI). They can easily get to the point where the deposit more or less fills the back of the inlet valve/port.
It might be a big job but I'd be considering having the head off for a general clean up. You'll probably find the components themselves are OK underneath all the crud.
It'd be nice to get access to a bore-scope (endoscope) and have a look down the holes, but that might not be easy to come by. I wouldn't be surprised if you can't get some USB plug-in mini camera these days for a few bucks from China.............
Cheers. That's the plan - to try and clean up as much as possible rather than give this guy carte blanche to rebuild!
compression kingy916 SV Talk, Tuning & Tweaking 3 30-01-09 02:48 PM
Avatar compression help? MeridiaNx Photos 9 25-07-07 05:12 PM
Low compression, possible causes? bikedoc SV Talk, Tuning & Tweaking 8 26-01-07 07:19 PM
Movie compression lukemillar Idle Banter 7 08-08-06 11:05 AM
Low Engine Compression CamScooby2 SV Talk, Tuning & Tweaking 2 02-06-05 10:52 AM
