#11 |
Drag mate, I don't think a "Pro" is needed...well not yet anyways.
Just need to appraoch the sitution in a logical manner. It could indeed be front or rear causing it..... First thing is to check everything is adjusted correctly/torqued up right. ie chain, Steering , wheels etc . You said Ter had the forks set up for track....what exactly has bee done to them?....ask Ter. Ben |
#12 |
how was the bike with the ZX shokky before the front end swap?
#13 | ||
#14 |
weave/tank slap - large handful and it snakes...
chatter = tyre skipping on the road surface. if it runs wide on exit you need more rear compression. try this http://www.moto-racing.co.uk/Guides/...up.htm#DAMPING |
#15 |
Ah ha, deffo not a case of a tank slapper, so we just have chatter, @ the moment she's solid in the corners, but i'l a little nervous about flinging her in to the corners as the hard acceleration on the way out shows the chatter, much like straight line acceleration chatter, road surface of course makes it better or worse
#16 | |
#17 |
Fudging irish roads, more like dirt tracks !!!
#18 | |
another thing is, if the rear of the bike is higher than standard and you have put a GSXR front end on which is lower than standard then its going to be very twitchy and unstable at high speeds. also very sensitive to handlebar input. click the rebound up a couple on the front and see how it goes.. i know mine had a really bad weave at about 80ish because the suspension was to 'soft' (more reactive less damped) at the front. |
#19 | |
I know the bolt was close to the dog bones when we fitted it, but i dont think it's catching on the bones, i'll see if we can check it over the comming days. i've a 120/70 on the front so , it's ment to be the closest to the stock front end. |
#20 |
oddly - you may find you have too much rebound on the front and the forks cant extend quick enough so they pump down and then bottom out which causes the chatter. conversely this may be not enough compression...
but hey if its fine going in, just get the front wheel off the ground on the way out - hey presto no more chatter ![]() |
Crash.NET - Stoner subdued by chatter. | NewsBot | News | 0 | 27-04-09 08:50 AM |
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) | leegriffiths128 | Stuff Wanted | 0 | 23-07-08 09:11 PM |
Crash.NET - Chatter at Kawasaki... | NewsBot | News | 0 | 13-07-07 05:20 PM |
Front end chatter on heavy braking - wtf? | thor | Bikes - Talk & Issues | 16 | 18-05-07 10:18 PM |
Crash.NET - Nakano 'still suffering chatter problems'. | NewsBot | News | 0 | 24-02-07 04:44 AM |
