Old 25-08-09, 01:29 PM   #11
Lucas
Default Re: Non starter, full battery
Originally Posted by noob-saibot View Post
electrical fault finding step by step jobbie from electrosport
whatever that is, i may need one, what is it?
Old 25-08-09, 01:51 PM   #12
drag
Give us a shout if you need a hand/head lad. Ive got the new optimate yoke that tells ya if your battery is good/poor/dud. Also ive an electrical fault finding step by step jobbie from electrosport that i had to use many times for my electric gremlins months ago.
I'll txt ye slater so, it's still charging away, which seems odd as the bugger wasnt that far off fully charged imo
Old 25-08-09, 02:04 PM   #13
Lucas
Was it a cheapo battery?
Old 25-08-09, 02:05 PM   #14
drag
hell no 70 euro ( real money ) about 55 pounds i guess
Old 25-08-09, 03:06 PM   #15
noob-saibot
Here ya go. Its ok but you have to think outside the box aswell. Turns out my problems were a combination of dodgy reg/rec and dodgy reg rec to battery wiring at the same time..
http://www.electrosport.com/technica...ding-guide.php
Old 25-08-09, 03:26 PM   #16
Lucas
thanks
now you mentioned the combo problem you had, I had a similar issue but not sure. I had a duffed reg, now got a working second hand one and all is fine but...
here's the question (sorry for hi jacking thread) with engine at idle, is it normal for the regulator/rectifier's negative wire (the black with white stripe) to get warm to the touch? (is it because it carries a high current to charge the battery?)
or could it be casued by dodgy reg rec to battery wiring?
Old 25-08-09, 04:39 PM   #17
drag
Battery practically charged any way, stuck it in, fired up, after a bit of fiddling with the starter motor, seems it's given up the ghost, off the the suzuki dealer, and picked up a new one, i'll fit it in a wee while so.
Old 27-08-09, 07:36 AM   #18
Lucas
All sorted? was it the starter?
Old 27-08-09, 07:00 PM   #19
drag
Starter relay actually, seems the contacts were fecked, so i replace the unit, for 60 euro, well worth it for piece of mind i guess ..
Old 19-09-09, 07:57 PM   #20
stu sv
i had same prob last year then it went totally dead no ignition lightd put jump leads on and it was tuning over with no keys in turned out to be the relay which then cooked the battery
Possible swap, Full Leo Vince for Full M4? weecorey Stuff Wanted 2 26-06-09 11:45 PM
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
Non-starter for ten... Bluewolf SV Talk, Tuning & Tweaking 6 23-08-07 09:21 AM
Akrapovic full system or yoshi full system ? ? ? hall13uk Exhausts 40 15-08-07 11:44 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
