Old 12-09-09, 01:32 PM   #11
Alpinestarhero
Default Re: Oil leak :-(
second wemoto. You can also try robinsons foundry for genuine suzuki spares.
Old 12-09-09, 07:37 PM   #12
7755matt
Many thanks
Old 16-09-09, 10:59 AM   #13
7755matt
Ok, I fitted the oil seal today but its not flush. As it was going in, looks like one side is further in than the other. Im hoping this will be ok?
If not, i have a second (always good to be prepared)
Old 16-09-09, 02:02 PM   #14
Seal should fit in flush, what are you knocking it in with?
Clutch pushrod seal is not under much pressure but crap can get dragged through it. output shaft seal is a possible culprit, not easy to change though. These leak much more in motion, not usually when stationary.
Old 16-09-09, 05:35 PM   #15
7755matt
I was pushing it in by finger pressure then a socket to tap it in. Didnt hav e a socket that was an exact fit though.
It was the pushgrod seal that had gone, The new one ive fitted doesnt seem to be leaking. If it does start to leak then I'll refit it using a decent something to push the seal in flush
Help oil leak puter killer SV Talk, Tuning & Tweaking 8 08-01-08 12:29 PM
oil leak? will SV Talk, Tuning & Tweaking 4 04-03-06 05:01 PM
Oil leak - help! Warthog SV Talk, Tuning & Tweaking 9 03-02-06 04:09 PM
Help - Oil leak. adam SV Talk, Tuning & Tweaking 6 11-04-05 06:22 PM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
