Old 14-09-09, 12:28 PM   #11
Default Re: Vibration like anti-lock brakes
That would be the chain slapping about if you get close to stalling it and the engine is chugging.
Check the pads in the calipers are mounted properly on the steel springs in the top of the caliper body.
Old 14-09-09, 12:44 PM   #12
rpwoodman
Ahh, cool, a reason - thanks YC. I'll have a look at the pads - would it be obvious if they're not mounted correctly (to someone who doesn't do their own servicing)?
Thanks
toblerone_rupe
Old 14-09-09, 02:34 PM   #13
It's fairly obvious where they should sit on the spring plates.
I have known this to cause a slight shudder. No idea why though. BUT it did it every time, not just under very hard use. I think you should go try brake hard and see what it does.
Old 15-09-09, 12:11 PM   #14
s7uyj
just a thought, possibly locked up the back wheel slightly causing it to 'skip', basically if it doesnt lose enough traction to slide, but kind of judders over the road?!
Bar Vibration SAMMY650 SV Talk, Tuning & Tweaking 5 19-06-08 06:08 AM
ignition lock, seat lock, and key adam_castell For Sale - SV's and SV related items 0 27-02-07 07:56 PM
steering lock to lock??? thumper SV Talk, Tuning & Tweaking 16 29-01-07 07:17 PM
Vibration Grinch SV Talk, Tuning & Tweaking 7 12-01-07 03:17 PM
Anti British and anti American threads - crass and boring Ed Idle Banter 40 13-06-06 06:08 PM
