Old 21-09-09, 08:52 AM   #11
Dave20046
Dave20046's Avatar
Default Re: front diving
A few points;
You should be measuring air gap, not oil volume. Especially when doing half a job by pumping the oil out.
Oil weight in stock forks affects rebound mostly.
Air's measured in volume
You're right though I did do it by air gap, I just used an engineers ruler - not sure if there's a more technical/exact method.
P.S you get out of sheff alright last night? The bottom of the road was police taped off this morning
Not unusual... but I did half expect to see some little scrote layed out next to a speed bump with a set of forks through his face.
Old 21-09-09, 09:07 AM   #12
Lol yeah fine.
Yes you are measuring air gap volume, but the air spring effect of 100cc will be different in a 28mm fork to a 50mm one, so better to measure air gap in mm.
Old 21-09-09, 11:01 AM   #13
wizard
cheers for the info lads! will just try and adjust the preload for now and see how i get on from there
Old 21-09-09, 11:16 AM   #14
Dave20046
Dave20046's Avatar
Maybe worth measuring the forks to see if it's bottoming out? Adjust the preload and put a cable tie round one of the stanchions on the forks (not too tight) then after a hard ride see how close the cable tie has pushed up to the bottom yoke. Will give you an idea of which way/how much to adjust the preload.
Old 21-09-09, 11:19 AM   #15
Or is it measured in specific volume, density, pressure, mol, entropy, enthalpy etc?
If you really want to complicate things...
A simple length is much easier to work with.
Old 21-09-09, 11:20 AM   #16
Dave20046
Dave20046's Avatar
Hence why I used a ruler
Just was trying to excuse my shoddy post!
Old 21-09-09, 11:25 AM   #17
fastdruid
fastdruid's Avatar
Just remember that it's measured no springs, full compression, otherwise you'll end up with virtually solid forks!
Druid
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
Downhill diving pogo suspension cornering confidence stuartyboy Bikes - Talk & Issues 6 09-08-06 11:14 AM
Diving with Sharks simple simon Photos 18 23-07-06 02:51 PM
Granny Diving Kinvig Idle Banter 5 07-07-06 07:43 AM
