#11 |
Emily Howard rides an SV
Agree with Fizz here.
The bike and a good set of tyres will easilly out perform most normal riders' ability i'd say. It's probably a confidence issue at a guess. But what ever you do don't go out of your comfort zone, especially when on the road. Do a track day and then see how you feel after. Get some tution as well if you feel the need. ![]()
Wowee
#12 |
I don't think anyone can say without seeing you ride really. You could be the next Rossi or you could be wobbling around at 30mph worrying about nothing
![]() Changing the stock tyres for some newer, better ones will probably make a big difference. It is likely that it's a confidence thing but the only reasonably safe way to explore the limits of you / your bike is to get on a track day. My advice? Don't bother chasing Lotii (have I just made that up?!) through the countryside - it could end in tears and tears. ![]() |
#13 |
Have been thinking of doing a track day for a while now.
I've no doubt it would help me improve in most areas of riding but am a little worried about binning it. I looked into hiring an R6 or something similar for an afternoon and surprisingly its not too expensive. Trouble is that any learning on that will be pointless when jumping back on the SV on the road. ![]() |
#14 | |
![]() Id start with set up.What tyres are you on,at what pressures and how heavy are you?Then look at technique.I use little or no rear brake when braking hard on the SV and trail braking the front into a bend is a skill best left to racing types on track IMO.Id do a track day to get a real feel for the bike where its safe to do so.
#15 |
if your around the devon area your welcome to sling a leg over mine, its got stiffer front springs and avon storms. i was very unhappy with the standard dunlops that were fitted to mine, had the same issues as you and could easily spin it up coming out of roundabouts(this was usually done on purpose for a bit of fun) now its bit of pain cant go wheelspin up the road from work even if its wet the avons grip better then the dry dunlops
#16 | |
i agree with fizz and others, you've probably got loads left before the limit on the sv, but a better set of tyres will most likely help things 'feel' better and inspire a bit more confidence. a track day and/or some more training are a good way forward too.
AR08 to AR13-QUALITY! 650s: '52 curvy in yellow, was my baby ![]() cbr600rr: Mivv exhaust and a bagster tank cover. Now gone to a new home. Daytona 675: Arrow can (with a baffle that's gone missing in action.... ![]() ![]() |
#17 |
I have had Metzeler Z6's on and BT 021's, and both of them allow you to grind your pegs perfectly happily on the road, so its normally skill or poor standard tyres that are to blame. Getting new tyres often gives you a confidence boost too.
#18 |
Buy some crash bungs and then get on a track, its the best and safest way to explore yours and the bikes abilitys
#19 |
i was going to say my back end on good tyres kicks out of i downshift to quickly without blipping the throttle, so quiet often, i just got used to it. try using the front brake more gets the weight off the back wheel, and if the front end feels bad when braking try new tyres.
Also do people really use the rear brake? i know my mot station showed about 90% brake efficiency for mot before i got the bike and after a year of owning it, i dont think i have ever used it, engine + hard on the front is enough to stop quicker than any car driver is willing to. |
#20 | |
How bad are standard tyres. | Jackie_Black | Tyres | 22 | 31-12-08 02:43 PM |
Is ignorance the path to true riding enlightenment?(limiting skills by bike choice?) | K | Bikes - Talk & Issues | 31 | 11-03-07 06:49 PM |
What tyres from standard? | dmracing | SV Talk, Tuning & Tweaking | 21 | 30-03-06 11:04 AM |
The standard Tyres | The Mass | Tyres | 8 | 15-03-05 02:21 PM |
standard tyres on new k3/4? | edcase | Tyres | 2 | 17-06-04 09:11 AM |
