Old 22-09-09, 08:21 PM   #11
fastdruid
fastdruid's Avatar
Default Re: Reduce Force of Throttle Return Springy Thingy
the only spring I can think would affect it is on the carb, however not something I'd mess with (could be wrong though)
Depends on which year as to exactly how it works but if it's a curvy then
You see that big fat spring bottom left *and* top right of the carbs (as they are sat there), those are the throttle return springs and you'd need to remove and *modify* both.
Druid
Old 22-09-09, 08:26 PM   #12
Dave20046
Dave20046's Avatar
oops forgot about the fi models - and I own one!
Old 23-09-09, 08:38 AM   #13
boot
Originally Posted by fastdruid View Post
Depends on which year as to exactly how it works but if it's a curvy then...
Druid
Yeah, it's a curvy. Woo - don't fancy messing with those buggers. Thanks for the heads up.
Looks like I'll have to try an o-ring.
Cheers folks!
Old 23-09-09, 08:43 AM   #14
hovis
what would happen if you disconected one of the cables to the throttle?
im sure i did this to my curvy cos it was sticking........... although i may have made the whole thing up
Old 23-09-09, 08:50 AM   #15
Dave20046
Dave20046's Avatar
LOL, at a guess it'd run like a bag o' ****e. one cylinder would be getting fed at tick over speed one would be getting the right amount of fuel.
Old 23-09-09, 08:52 AM   #16
fastdruid
fastdruid's Avatar
Er no, one cable is the 'pull' ie open the throttle cable, the other is the 'push' ie close the throttle cable. Removing one wouldn't make any difference.
Druid
Old 23-09-09, 08:53 AM   #17
hovis
Druid
except it may not spring back so fast?
Old 23-09-09, 08:57 AM   #18
Dave20046
Dave20046's Avatar
Druid
Ah, I was thinking if you unhooked the throttle cable from one of the carbs. doh
Old 23-09-09, 09:00 AM   #19
fastdruid
fastdruid's Avatar
No. If anything it may spring back faster as you'd have half the friction.
Druid
Old 23-09-09, 09:01 AM   #20
fastdruid
fastdruid's Avatar
The cables only attach to one carb, the other is actuated by a linkage.
Druid
Crash.NET - Swine flu fears to reduce Spanish GP fans? NewsBot News 0 29-04-09 02:40 PM
Crash.NET - Swine flu concern to reduce Spanish GP fans? NewsBot News 0 29-04-09 12:40 PM
Throttle return cable? Stevetmanchester Stuff Wanted 0 20-10-08 10:27 PM
throttle return cable 01 sv650s SV Talk, Tuning & Tweaking 4 24-11-06 12:24 PM
KBC force air Grinch Helmets 7 04-03-05 07:12 PM
