Old 24-09-09, 10:03 PM   #11
Ruffy
Ruffy's Avatar
Default Re: What are the dangers of over springing?
Spring rate too soft for nearly everyone...
Therefore, it would seem to lead to the conclusion for the OP that, if you can't get it right, slight overspringing is better than underspringing.
The key issue then being that the rear end won't squat as much on cornering, acceleration or over bumps.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
Old 24-09-09, 10:10 PM   #12
But a little bit of wallow is better than a big bit of highside if it pings over a ripple cranked over.
OK set a gauge length somewhere, like from swingarm bobbin to grabrail, say this is 300mm with suspension fully unloaded, then with weight of bike it might be 290mm and with rider aboard it might be 270mm
This would mean your bike sag is 10mm and total sag is 30mm.
Old 24-09-09, 10:12 PM   #13
DavieSV
DavieSV's Avatar
Warning!! racing talk approaching
I have a little feeling that may have contributed to my off (Seggons where is that video) I think the suspension was compressed, then mid bend hit a low spot in the road which extended & compressed the rear end in a very short space of time, causing the rear to let go momenterily
Yeah, that's what happened, It wasn't me riding like a ***
DavieSV is offline   Reply With Quote
Old 24-09-09, 10:16 PM   #14
But good suspension can let you get away with being a muppet to some degree, which is ace.
Old 24-09-09, 10:21 PM   #15
DavieSV
DavieSV's Avatar
That's what I want, idiot suspension to go with my idiot tyres
Ham fisted entry, wobble in middle, ham fisted exit. brill
Old 24-09-09, 10:24 PM   #16
Or you could keep the naff suspension and buy better leathers instead lol.
Old 24-09-09, 10:52 PM   #17
zadar
lets say you have 3 springs, 425-450-475# spring. 450 is ideal for you but somebody stole it. Personally I would use 425. if I have to use 475 I would set it with less preload. softer will absorb bumps better and give more grip at tire.
Old 24-09-09, 11:00 PM   #18
DavieSV
DavieSV's Avatar
But how do work out what is right?
Old 24-09-09, 11:06 PM   #19
Stock for pointy is about 430 I think.
Racetech will give you a guess, but it is a ballpark figure.
Old 24-09-09, 11:08 PM   #20
zadar
suspension shops know what is right.
Vale of glamorgan dangers blue curvy jester South & West Surfers 0 11-09-09 01:57 PM
Dangers of horseriding oldjack Idle Banter 66 26-03-07 11:05 PM
re-springing a shock weazelz SV Talk, Tuning & Tweaking 19 03-12-06 06:22 PM
