Old 28-09-09, 08:06 AM   #11
Default Re: The SV tool kit is next to useless ?
Kwak has whipped it out a time or two and found what he wanted to tinker
Old 28-09-09, 11:09 AM   #12
Alpinestarhero
I've put a few bits in my toolkit, like a long 8mm socket to get to the bolts for the front clutch cover and some other things to adjust the clutch at the roadside if need be.
RE: the lag; try getting the carbs balanced (or is it an FI bike? cant remember your opening post now) and (if it is carb'd) get the chokes cleaned up. Spannerman did this to my bike, and I dont have that lag you describe anymore. Used to though, it was horrible
Old 28-09-09, 11:59 AM   #13
no_akira
Dont get me wrong i'm not a whinging pom, it doesn't detract from what is a great bike, nice and quick (once your rear brake is not seizing), narrow for sqeezing through cagers, plus 50+ mpg.
Like all things in life its a compromise between weight / cost. A clam style rear brake for easy maintenance would have added to the initial price along with adding another 2 spark plugs.
All they need to do now is make the next model a shaft-drive and it would be the ultimate couriers bike. A modern retro version of me old mucker ("Punchy") the Revere !
I do love the amount of work thats gone into making the curvy frame, its a modern day piece of art.
Will try Alpines suggestion and look into balancing the carbs, i've got a twin kit in the garage from my Gpz305 days.
Old 28-09-09, 04:05 PM   #14
Sosha
Could be you're missing a few bits and pieces - mine had allen keys - though to be fair other than the spark plug spanner it aint great.
Old 28-09-09, 04:08 PM   #15
zsv650
i wish i had a sv tool kit to moan about last owner half inched it the *******.
Old 28-09-09, 06:22 PM   #16
Originally Posted by no_akira View Post
There is no slim fitting 11mm tool to remove the clutch cable / socket cover.
11mm
There's only one 11mm hex on an SV - and that's not it.
Old 28-09-09, 06:28 PM   #17
2hys
I always throw the tool kit in the shed and forget about it.
I have decent tools to use at home and an RAC membership if anything goes wrong on the road.
need i say more
Old 28-09-09, 06:29 PM   #18
hovis
11mm
go on then, where is it?
i just replaced all the crap tools with a few better ones. (its still pretty basic, but better than standad)
Old 28-09-09, 06:48 PM   #19
I needed to use my toolkit the other day. Both my bikes should have a full toolkit, plus a few extra pieces....
so why is it everytime I go under either bike, Mr Nobody has been using them and hasn't put them back how they found them
and I need it at the side of the road..grrrr
Useless doctors BanditPat Idle Banter 14 08-04-09 10:30 AM
When did the org become so useless!! phil24_7 Idle Banter 67 17-08-08 11:54 PM
SV Tool Kit/Spark Plug tool svdemon Stuff Wanted 1 17-12-07 12:29 PM
useless poster hovis Idle Banter 118 20-11-07 07:45 PM
My god i'm useless at.. steveo Bikes - Talk & Issues 22 31-12-04 11:13 AM
