Old 28-09-09, 08:59 PM   #11
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Urgent rear brake help PLEEEEEAAAASE
Originally Posted by Jay1 View Post
it is going to work out cheaper to get a used calliper.
Unless of course you get a naff caliper from an unscrupulouse (sp?) seller who says it's good but it's not
2011 Speed Triple 1050
Old 28-09-09, 09:11 PM   #12
lee67
bandit and sv calipers are slightly diff...the pads are the same tho..infact bandit pads fit numerous calipers
Old 28-09-09, 09:16 PM   #13
Jay1
Hmmmm, so I couldn't put a bandit calliper on the SV then?
Old 09-05-11, 09:41 AM   #14
trail guru
Default Re: Rear brake cailper seized.
My K3 rear calliper pin is seized, despite a week in WD40 and heat treatment. Given that you can't knock it out 'cos it's a threaded 5mm Allen bolt what's the next best step?
Old 09-05-11, 01:18 PM   #15
Grip the pin in vice and apply more heat.
Rear Brake Pad Holding Pin Seized madeye SV Talk, Tuning & Tweaking 9 14-12-08 02:49 PM
Front brake calipers seized Dai-Cymru SV Talk, Tuning & Tweaking 37 02-12-08 02:53 PM
front brake problems(seized pins) dangerous bri SV Talk, Tuning & Tweaking 1 12-03-07 07:16 PM
Seized brake piston? xlewdx SV Talk, Tuning & Tweaking 13 13-11-06 09:49 AM
Seized brake pistons - best course of action? Dom_ SV Talk, Tuning & Tweaking 10 03-07-06 09:53 AM
