#11 |
aree its white 6 wires 5 black and white 1 black has metal bridge and a black cap!!!!!!!!
#12 |
The Sick Man
![]() ![]() you should have white: number plate grey & black: L & R indicators 3wire connector = rear light and stop
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#13 |
its the block in bottom right corner and its the blacck wire i dont know wher that goes.
cheers craig |
#14 | |
The Sick Man
if you continue down the loom, there should be another 6 wire bridge block, it goes into that, well thats the black with white tracer and its thicker than the other 5 wires if you are talking about the thiner black wire in my pic that goes off to a 4pin brownish plug, i dont know what it is, but ile hazard that its a flasher relay, not sure though
#15 |
my next 6 bridge connector is near ecu plug but only has 5 balck with white tracers in it it is a 6 way but only 5 in it! i have no brownish connectors!!!!
cheers craig and yes it s the thin black wire! |
#16 |
i have a black and white wiring diagram and maybe a colour diagram if thats going to help message me with your e-mail address and can send it to you.
#17 |
craigcaz@sky.com
always worth a look i have diagram but still struggling diagrams don't show these bridge things!!!!! |
#18 |
cheers sunshine
#19 |
cheers for all the help up to now. Hers were i am at at the back of bike there is a "bridge, white plug with a metal bridge in it" 6 wires in 5 of which are black with white tracer all the 5 go too left rear ind, right rear ind ,num light, and you guessed it brake light , i have one wire left which is black no where to go!!! my question is if you follow these white / blacks back (on wiring diagram) they go into various switches could this pesky black wire be holding my fuel pump out???? where should this black wire be connected to.
again cheers to all those that have helped me up to now Craig |
#20 |
up-date It looks like it goes to the ECM /ECU I think having had a good look no ignition switch signal to the ECU this is the anti tamper system. It must be close to the ECU area where the wire will be cut when the alarm was fitted. trubble is iv stripped loom back and can not for the life of me find where its been taken from any help pointer ???
cheers guys |
Curvy fork identification? | herbie | SV Talk, Tuning & Tweaking | 6 | 05-03-09 12:24 AM |
Engine identification? | aln | Bikes - Talk & Issues | 21 | 17-01-09 11:43 AM |
Lower fairing identification... | Gnome | SV Talk, Tuning & Tweaking | 4 | 29-03-08 09:42 PM |
SV1000 part Identification | Mark_h | SV Talk, Tuning & Tweaking | 15 | 22-11-07 12:23 PM |
Ohlins Shock (model identification) | ASM-Forever | SV Talk, Tuning & Tweaking | 2 | 01-04-07 11:27 AM |
