#11 |
Dropping the rear end is definitely an option, but personally I'd try other things first (e.g. cut out seat, getting off the bike to move it) before deciding to change the way that the bike itself sits.
Lowering the back will change the angle of the steering, so you will then need to drop the front forks to compensate, and possibly change the sidestand as well (depending on how much you change it by). Lowering will also reduce your ground clearance slightly - though this may not matter to you unless you plan on doing trackdays. I'm not a suspension expert, but I would suspect that dropping the front forks will affect how the front suspension works as well - though again if you're not pushing the bike hard this may not be a problem to you, and you can change springs/oil for not too much money anyway. |
#12 |
Simple - get off and push it when you're parking up. That's what I do
#13 |
What isn't clear from this thread is whether you're actually going to get the longer dogbones that make the bike lower. You're saying your bike has been jacked up so that means the back is higher than normal, so that needs to be returned to normal and then you go one step further and get the special, non-standard dogbones, that's what us shorties do to get the SV lowered. You can get them online cheaply those dogbones. Plus having the forks dropped. And yes some foam out of the seat helps too, don't know where you are but there are various companies that do it. If you're going to keep the bike it's worth while to have gel put in as the seat is a lot more comfy then.
Forgot: best to leave the suspension (pre-load), back and front, set up esp for you and not lower it and yes you will have to have the side stand shortened as well. Last edited by wow; 06-11-09 at 08:58 AM. |
#14 |
Well I hope you get it sorted
#15 |
In my opinion, don't soften the suspension.
It's too soft already, but some one with more technical knowledge(YC, Sid, Rictus etc) will be along soon to tell you properly. |
#16 |
Amanda, if you are 5ft2 and can get your toes on the ground, the bike can't be jacked up that much. I am 5ft6 and I can get only the balls of my feet on the ground and my bike is a standard curvy....
#17 | |
#18 | |
Silver SV650SK3, Fuel exhaust |
#19 |
Sorry to hear this
![]() I'm lucky as I'm quite tall so am able to paddle mine around - although i would prefer to push it, but cant as I have a dodgy arm. I always plan where and how I'm going to park as I can't move the bike backwards uphill, and always avoid gravel unless I'm with someone who can turn the bike round for me ![]() |
#20 |
Thanks for all the advice and comments peeps.
MBK - Don't get us 2 Amandas confused. I'm the 5' 4" and can only get my toes on the ground when centred. I'm fine when riding, stopping, slow maneuvers, etc. It is purely a reserving or full lock parking issue, if that makes sense. Anyways, I have been down to Moore again today and they have measured the bike after taking the dog bones out and luckily had some standard ones in stock exactly the right size I need. He is also going to lower the yoke by about an inch on the forks. Whilest we dropped it down I managed to get the ball of my foot down so with the yoke drop I should get the majority of my foot flat. Felt so much better!! They are such a good bunch down there that "Tubbs" said he has no work in tomorrow so he's going to do the lowering and my mods then have a go at the damaged bung AND then give the bike a good going over to see if there is anything else he can do to help. All at no extra cost!!! Just out of interest "Tubbs" is featured on page 105 of the December Fast Bikes. So I trust his judgement on the lowering. Very excited to get my Suzi back on Monday. Whoop whoop |
lowering kit | gerrymcghee | SV Talk, Tuning & Tweaking | 6 | 24-10-09 06:07 PM |
Lowering an sv | Reptile | SV Talk, Tuning & Tweaking | 9 | 23-09-09 09:34 PM |
SV-650 Peg Lowering Kit? | Denny Lee | SV Talk, Tuning & Tweaking | 4 | 16-05-06 07:12 PM |
Lowering an SVS... | Aaron_T | SV Talk, Tuning & Tweaking | 11 | 08-08-05 06:03 PM |
lowering........again (sorry) | jenni | SV Talk, Tuning & Tweaking | 4 | 27-06-05 08:35 AM |
