#11 |
#12 | |
Looks like another weekend of fiddeling ![]() On second thoughts, just checked my notes, tested the output couple of weeks ago was 13.5V with every light on full @ 3K RPM, so that seems to indicate reg/rec is OK Last edited by Old Git; 06-11-09 at 05:52 PM. |
#13 |
#14 |
It is quite possible that you have a duff cell which can be ok one minute or even weeks then nothing.Most gel batteries only last 2 years anyway.
#15 |
could indicate a faulty starter sprag clutch.....that manifests itself as nothing at the button, then will catch..sometimes works first go..othertimes nothing..
#16 |
Variations in temperature, and a steadily declining condition of the battery. And it could be losing charge every day until it eventually aint got enough left to start it.
Silver SV650SK3, Fuel exhaust |
#17 |
Yes.
#18 |
SV doesn't have a gel battery.
#19 |
You will hear the starter motor whirring if this is the case.
#20 |
no whirring just the mearest attempt to turn engine over, sounds as though it is flat battery, just couldn't get my head around if a battery can be fine used every day for 5 weeks, then go out next day seem as though it is flat, then bump start, run & be fine for another 2-3-4 weeks before the cycle starts again.
Optimate battery charger drains the battery | flymo | Bikes - Talk & Issues | 10 | 10-06-09 10:41 AM |
does this look dodgy to you? | Paul the 6th | Bikes - Talk & Issues | 4 | 15-01-08 10:01 PM |
Now this one is dodgy... | Mike1234 | SV Talk, Tuning & Tweaking | 14 | 04-01-06 09:51 AM |
Battery/Starting problem - new battery hasnt fixed it! | Aaron | SV Talk, Tuning & Tweaking | 13 | 24-01-05 05:21 PM |
