Old 01-12-09, 05:41 PM   #11
richiekuk
Default Re: Broken down
Dave20046, there were spare fuses.
It happened again today. Same thing, bike died, but all dash lights ets were working. Ignition fuse gone again.
Anyone got a curvy wiring diagram, so I can try and find the problem, or has anyone had similar experience, and can shed some light.
Richie K
Old 01-12-09, 05:56 PM   #12
Dave20046
Dave20046's Avatar
there's a block connector under ya tank infront of your airbox check it out.
Other than that it's be worth checking all the other connectors and terminals/contacts. but the above is my bet
Old 01-12-09, 06:32 PM   #13
Lissa
Just Ballast
Lissa's Avatar
Richie K
Any good?
Old 01-12-09, 07:11 PM   #14
Spiderman
Where the hell am I?
Spiderman's Avatar
If lisa's diagram is no good to you i have an haynes manual for a curvy that you can have for a good price. Seeing as i dont have a curvy anymore.
Old 01-12-09, 10:04 PM   #15
richiekuk
Cheers for the diagram. Bit blurred, but I can see what I need.
I'll do a bit if wiring fault finding when i get a chance.
Thanks
Richie K
Old 01-12-09, 10:11 PM   #16
beabert
i have a digital haynes if you need it, for only the curvy though.
Here are all the different european wiring diagrams
http://s19.photobucket.com/albums/b1...ng%20diagrams/
Old 02-12-09, 09:52 AM   #17
davepreston
recheck all earthing points, as dave numbers said check the front block betwen head stock and air box (ps its a fing pain to get at) and lastly check the block running from seat fuses tbh i think the 2nd one is most likely as we had this problem with badgers bike at GM11
Old 02-12-09, 01:48 PM   #18
richiekuk
Yeh, am gonna have a good check, once I can find a garage to strip it down in (bit cold and wet outside at the moment)
Richie K
Old 02-12-09, 02:09 PM   #19
timwilky
timwilky's Avatar
usual fault with curvy electrics is chaffing of the loom as it runs down the sub frame, especially near the seat bolts
Not Grumpy, opinionated.
Old 23-12-09, 08:59 PM   #20
richiekuk
Right, found a dodgy wire, that was hidden by some insulating tape. It was seperatding and reconnecting!
Dodgy wiring by previous owner me thinks!
It all seems well now. Hopefully for ever, as it was the only fault I could find!
Thanks for all the help guys! and Merry Christmas.
Richie X
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
I think I have broken a toe timwilky Idle Banter 10 28-07-08 04:58 PM
Broken dreams and broken lives. Peter Henry Idle Banter 7 15-09-06 07:43 AM
It's broken!!! :( alex.j SV Talk, Tuning & Tweaking 7 30-08-06 08:50 PM
My Broken SV sharriso74 Photos 6 30-07-06 09:10 PM
