#11 | |
If the bike runs, then this isn't your primary problem. I'm pretty sure the fuse box for a K3 is under the front seat, or possibly under the rear. Best Regards Jambo
#12 |
Front seat on a pointy Sir Jambo
#13 |
It's an S, I also forgot to mention I had checked the fuses, none had blown. The lights never dimmed, they just went out all of a sudden.
I will check the plug under the tank tomorrow. |
#14 |
yes they do but a diforent front loom
![]() ![]() dident see the above post shorting wire ? Last edited by barwel1992; 30-11-09 at 11:51 PM. |
#15 |
My bike (K4) is doing something very similar - went to the garage this morning and had no dips - main beams worked ok. I can get the dip beam to work by jiggling the wire under the clocks inside the fairing nose, unfortunately it was too dark to see what's up with it!
I also had a lot of flicker riding in where the uneven road surface shakes the head around |
#16 |
my k5 svz1000 did this still had side lights and it was yellow plug under front of tank while your in there unplug the other 2 and treat to some electrical grease think mine was a yellow connector and a yellow wire wasn't that obvious to spot but when i split the plug the plastic had melted and was causing bad connection / resistance.
#17 |
p.s sorry black connecto yellow wire , sorry for poor pics but thought may help.i just sniped offending wire each side and re wired with a electrical connector p.s bet you have lost your pass light as well!
H.I.D H4 for sv hi low beam | ging6996 | For Sale - SV's and SV related items | 4 | 28-07-09 04:49 PM |
low beam not working. | Slash | SV Talk, Tuning & Tweaking | 3 | 26-09-08 02:28 PM |
Which head lights should be working in dipped operation? | Dirk Eisner | SV Talk, Tuning & Tweaking | 5 | 23-10-06 02:26 AM |
Headlamp Beam Deflectors | Banus | SV Talk, Tuning & Tweaking | 4 | 04-04-05 09:21 PM |
Full or Dipped Headlight | sevy | SV Talk, Tuning & Tweaking | 16 | 15-07-03 12:46 AM |
