#11 |
First thing to check is the Plant life in there , the Plants will happily Oxygenate the Water . If you are going to fit a pump then I would be inclined to spend the money on a good pump that filters well and provides UV filtration too for that larger Pond . These MAY not be necessary though . I`ve seen many ponds that had a nice balance to them because they did not have too many Fish in them and the Plant life could cope with it quite nicely . As the temperatures fall , the Fish will be inclined to eat less so I wouldn`t be too worried about going down there everyday and bunging food in there . When the temperature drops to around 8 degrees the Fish will stop feeding , it may even happen around 10 degrees . As the temperature drops even more the Fish will head for the bottom of the pond and for all intents and purposes , will hibernate for want of a better word . They will move around , but they wont patrol as much . If they do get hungry then they will rummage about for morsels . The danger you have with bunging food in there is that it doesn`t get eaten and stagnates and starts to produce Ammonia .
Ooh just remembered , you may be better off adding small amounts of Trace Elements over the Winter . Now is the time to learn your art Phil , as the problems will certainly arise more in the warmer months . Get yourself a Water testing kit as well to test for Nitrates and Nitrites , Ammonia and Ph . Last edited by xXBADGERXx; 07-12-09 at 04:47 AM. |
#12 | |
#13 | |
Not sure on the fridge pump idea, as it won't be waterproof and I'm not a fan of being electrocuted! |
#14 | |
What the hell are trace elements though? ![]() How much am I looking at for a decent pump/filter/UV system, and what brands should I be looking at? How often should I have the pumps on over winter and summer? I will try to find a water testing kit this week. Cheers for everybody's help. |
#15 |
Oh, I've just remembered.
I have a couple of waterproof switches outside, with wires coming out the bottom. One operates the pump/filter (I forget the name, but I will go and check) and the other doesn't appear to do a lot. I have traced the wire, and it appears to go under the water in the top pond. What the hell is this for??? |
#16 | |
That is a very good price on a UV clarifier and filter system . It doesn`t matter about filtration so much over the winter . You really need a hassle free pump to be honest . If it gets clogged you can actually run them dry and knacker them . A pressurised system like the one in the link will provide good movement of Water . In the summer months you will need to provide more filtration than in the winter . Ok , Trace Elements . These are measured in teeny weeny amounts and are little essential minerals that your plants will need to replace in the water , happy plants , happy fish . In the wild , Koi will get all their trace elements from the snow melt that happens in Japan . The snow returns back to a liquid form and picks up all sorts of stuff on it`s way down through the soil and clay of the hillsides and it then runs into the Koi ponds . We have no such facility here and our water companies will remove a lot of these in their process . Some pond fertiliser tablets may have these in by the way so it is always worth asking your supplier when you get one . |
#17 | |
#18 |
I'll pop to a pond supplier this week and have a chat and purchase supplies.
The pump I have in the small pond at the mo is a Fish Mate, pressurised filter, 2500UV. The inlet tube comes from the bottom of the pond and the outlet goes to the underside of the water feature, this then trickles down back into the pond. I guess I'll have to jump in the pond to find out what the heck I have in there already... That's gonna be cold! I'll post up some pictures soon so you can see what your helping me with! |
#19 |
Ha, ha. The link you posted is for the filter I have in my small pond!
This surely means the power wire that goes into my pond, is not a UV filter, as that is built into the pump?!? Could it be for oxygenating the water? |
#20 |
Well there you go , that is a bit of a coincidence as I thought "He`s gonna have a fair amount to do so let`s see what would suit him best for the money" ..... lo and behold . The one I was gonna recommend was the one in the link but nearer the bottom as it shifts more water per hour . Not all Pumps come with a UV clarifier built in , that lead may have been for a waterfall pump or indeed it may have been for a UV filter and seperate pump and the original owner put a Fish Mate in or something . It could even have been for underwater lighting , the possibilities are long and boggling as to what that lead could have been for or IS being used for right now .
mrs giggles has a fall into a pond | davepreston | Idle Banter | 10 | 03-07-09 10:17 PM |
trips over the pond | ginger-(sv)ninja | Idle Banter | 0 | 25-04-09 07:12 PM |
Who's life would you rather have had? | Berlin | Idle Banter | 15 | 08-02-09 08:04 PM |
Five Life now | Shellywoozle | Idle Banter | 11 | 10-06-08 10:08 PM |
And pond/pump experts in? | Daimo | Idle Banter | 5 | 23-06-07 10:28 AM |
