#11 |
It does indeed sound like cobblers. I also fail to see why a valve repair is so cheap compared to a piston repair (whatever that means exactly) as there is a lot of labour in both. Unless it's dropped a valve though it should still run even badly
#12 |
Bike has always been stored in a garage.
I'm going down to the bikeshop now and will see what they say. Thanks for responses. |
#13 |
On the VFR400 the barrels are part of the cases, so to replace a piston you need to drop the engine and split the cases[1].
To replace a valve you just need to pop a head off which you can do with the engine in the frame. Still not a simple job but far simpler than doing anything with the pistons. To do the same job on the SV would be a fraction of the cost as the barrels are separate to the cases. Druid [1] you _may_ be able to drop the sump, unbolt the conrod and pop it out that way, never thankfully had to do anything like that. ![]()
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#14 |
Ok just got back from the shop.The guy doesn't know what's wrong with it.
What he's done is; He did a compression test. There is some compression, but not enough for it to run. He thinks it may be a sticky valve, which he thinks he can cure by using a hammer and "gently tapping" it. He said, if this doesn't sort it, chances are it will be a piston. |
#15 |
Hmph, will look forward to finding out what it is that is wrong.
As said though id imagine that it could run on 3 cylinders, my dads old 400 four got him home on 3 cylingers, the 4th had exited the engine! he he. So I cant see why you would have absolutely no start. What is happening when you go to start it? |
#16 | |
#17 |
If its a "sticky" valve, then it would be wise, would it not, to have the ehads off and have everything cleaned, right?
Could it not be a head-gasket (or other gasket) problem? Mind you, my dad had that problem on his VFR, and the engine ran but only on 3 cyl. I think it is work popping the heads off...its not like its a horrible task, gear-driven cams mean everything just lifts out, no cam chain tensioners etc to worry about and resetting the timing is easy |
#18 |
The starter motor sounds like it's on speed. (faster than normal)
That's about it, it doesn't start, simple as. |
#19 |
Does it sound like the engine is turning over at all?
#20 |
I'm not sure it's been quite a while since I had the bike, they are taking ages to sort it out. They've had it a week and only done a compression test.
I think it was turning over, but can't be sure. |
For Sale: VFR400 NC30 | EssexDave | For Sale - Other Bikes and General biking items | 2 | 13-10-09 08:10 AM |
VFR400 breather hose | EssexDave | Bikes - Talk & Issues | 5 | 22-09-09 08:28 PM |
Honda NC30 VFR400 | BigFootIsBlurry | Bikes - Talk & Issues | 12 | 30-04-09 12:35 AM |
FOR SALE - VFR400 NC24 D Reg | geodudeft | For Sale - Other Bikes and General biking items | 2 | 10-04-09 05:25 PM |
Honda VFR400 | arc123 | Bikes - Talk & Issues | 12 | 20-04-05 11:24 AM |
