View Poll Results: How many performance parts have you purchased for your SV?
None 15 23.81%
1 9 14.29%
2 3 4.76%
3 10 15.87%
4 or more 26 41.27%
Voters: 63. You may not vote on this poll
Old 24-12-09, 06:04 PM   #11
fastdruid
fastdruid's Avatar
Default Re: Please vote. How many...
I didn't even need to rejet from 700cc, exhaust and air filter, took it to the dyno and the guy said "well it's running a touch rich, you could leave it as is, I could rejet it or I could just open up the air filter a bit more...
Druid
Old 24-12-09, 06:06 PM   #12
fastdruid
fastdruid's Avatar
Is that a joke?(can't tell)
I was under the impression you'd need to map/jet to get any gains from an exhaust let alone just the can.
72@rw with just the exhaust/can, no jetting changes.
Druid
Old 24-12-09, 06:08 PM   #13
Dave20046
Dave20046's Avatar
Druid
wow never knew that, always assumed you'd need more fuel mixutre going through to match the exhaust to get any gains. Is the same true for FI do you know?
Old 24-12-09, 06:52 PM   #14
Jayneflakes
Jayneflakes's Avatar
Default Re: Poll: How many performance parts have you purchased for your SV?
My bike has things fitted to it that I think make it look better, but as for performance, I am not sure. Mind you and I am slowly chopping it up into a more Streetfighter style.
So far it has a double bubble screen and I removed the standard rear guard and fitted a rear hugger to start with, although to be honest they were actually fitted by the shop when I bought the bike. I am dropping the clip ons for a riser bar, but keeping the fairing. Dropping the over size Indi's and fitting smaller and brighter pretty ones and I have also fitted a new ECU, albeit a 33BHP restricted one.
So I have changed a few things and plan to change a few more. I have been reading up about all sorts of toys, such as big bore kits and race cans, but it will be a few years until I am can afford or legally ride a bike with these toys.
Hope that helps. By the way, I am purely a keen amateur and do not have any formal training in working on Motorcycles, how many others are like me in this respect?
Jayne you're a Pussy Magnet
Old 24-12-09, 07:00 PM   #15
sunshine
I started like that, then recovered a smashed up two stroke and learnt how to rebuild everything but the exhaust and forks, im terrible at it all but i know the basics on an old two stroke and im now doing anything that needs fixing/changing on the sv.
Old 24-12-09, 07:18 PM   #16
Ward_650
Well I class performance parts as anything that benefits attributes like power, braking, weight saving, handling, aerodynamics etc
Hope that helps
And thanks for all the votes already!
Old 24-12-09, 08:14 PM   #17
Stuff already done:
GSXR front end;
320mm brake rotors
4-pot calipers
HH pads
braided lines
about to be revalved to suit
heavier springs
synthetic fork oil
posh rear caliper
rearsets
decent rear shock
race cams
free'er flowing air filter
full M4 pipe
tank raisers
rejet
Stuff in the pipeline:
lightened flywheel
ported heads
busa pistons
bump compression
pod filters and another rejet or maybe some flatslide carbs
[Project:fire in the hole ... just waiting to find a crank to build the motor around]
Old 24-12-09, 10:04 PM   #18
fastdruid
fastdruid's Avatar
lightened flywheel
On this note I was wondering if a GSXR1000K5 flywheel would fit,only 610g, the same way round and doesn't mean going total loss.
Druid
Old 24-12-09, 10:08 PM   #19
I am looking at possibility of fitting rare earth magnets and skimming flywheel down to minimal thickness to hold together
Old 24-12-09, 10:12 PM   #20
fastdruid
fastdruid's Avatar
How much does the existing one weigh? The GSXR1000K5 is already fitted with rare earth magnets to get so light, in comparison for example the NC30 flywheel is 1.8Kg!!
I've got one anyway which I plan on seeing if it will fit.
Druid
Lowers purchased. metalangel SV Talk, Tuning & Tweaking 8 08-04-09 02:25 PM
Performance Parts Mike1234 For Sale - SV's and SV related items 8 10-02-07 01:16 PM
anyone know a site to find k4 sv650s performance parts? tompro019 SV Talk, Tuning & Tweaking 2 09-04-05 01:51 PM
anyone know a site to find k4 sv650s performance parts? tompro019 SV Talk, Tuning & Tweaking 1 08-04-05 11:41 PM
Just purchased my first bike! Balsca Soho Massive 3 11-12-04 10:02 PM
