Old 29-12-09, 10:45 PM   #11
JamesMio
Default Re: Recommend me a... File recovery programme.
If all else fails try these guys for data recovery:
http://www.kingdomit.co.uk/
"That **** on the push-bike."
Creatomatic
Old 29-12-09, 11:02 PM   #12
phil24_7
Can't get either ntfs undelete, or PC Inspector to work off of a flash drive. One doesn't even see the C drive, and the other wont scan it!
Old 30-12-09, 09:39 AM   #13
mr.anderson
mr.anderson's Avatar
Go to portableapps.com/download, download the Platform only. Install that onto a USB jobby.
Then go to http://www.piriform.com/recuva/builds and download Recuva Portable. Install that onto your USB jobby.
Plug into laptop and start recovering data.
mr.anderson is offline   Reply With Quote
Old 30-12-09, 10:04 AM   #14
phi-dan
phi-dan's Avatar
Hail lord geek... Please detail me the steps I need to put it on a flash drive, as i don't really want to put it on the laptop with the lost files.
Install the program onto your PC
Browse to C:\Program Files and look for PC Inspector File Recovery
Copy that folder across to your removable drive
(sorry couldn't reply last night - Windows 7 64bit through a wobbler on my PC and it's not happy. Back at work at geek central now so free interwebs!)
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 30-12-09, 10:05 AM   #15
phi-dan
phi-dan's Avatar
Haven't used that particular app, but I do like the portable apps platform / suite
Now: Blue FZ6 Fazer
Old 30-12-09, 10:47 AM   #16
madcockney
Portable apps are very good, not just from the fact that you want to carry all your essential apps around on a on a flash (memory) drive or a portable HDD and be able to run, but also in these situations. If files have been lost or deleted then there is always the possibility that you will overwrite the files that you are trying to recover with the recovery program if installed on the same drive.
Just another matter if you have a virus on your system and then get rid of it/them don't forget to afterwards turn of the roll back restore facility in windows so it deletes any previous restore points that may contain virulii. You can then turn it back on if you want to.
madcockney is offline   Reply With Quote
Old 30-12-09, 12:21 PM   #17
phil24_7
I happened upon Recuva last night, installed it onto the USB drive and it ran without any problems. It recovered over 72000 files, so once I'd sorted through the ones I wanted, and recovered them, it was 05:30!
That portable app looks quite good, I may put that on one of my flash drives for future use.
Old 30-12-09, 12:22 PM   #18
phil24_7
I didn't do this... Schoolboy!
Old 30-12-09, 12:23 PM   #19
phil24_7
It worked where the others wouldn't (due to them being installed straight onto the flash drive I expect), so I rate it.
ace programme. tres interesting Quiff Wichard Idle Banter 5 19-11-09 12:12 AM
Would you save a stranger? (TV programme) ThEGr33k Idle Banter 26 03-04-09 04:37 PM
Which 70's TV programme is the best Kinvig Idle Banter 21 25-02-09 04:59 PM
interesting programme on TV.. Stingo Idle Banter 16 05-04-07 08:59 PM
What was the programme called... Ed Idle Banter 6 12-10-06 08:37 PM
