#11 |
As others have said, ping is a tool that reports round trip time for one computer to see a second. It is basically the same tool as traceroute (tracert for you windws types) whereby a number of "hops" is specified and the ping message sent out with an increasing hop count in the packet.
Many bastion firewalls will not respond to ping etc for the reasons specified by TSM DNS is the domain name service that translates names such as forums.sv650.org into an ipaddress. At a command window type "nslookup forums.sv650.org" for an example
Not Grumpy, opinionated. |
#12 |
To put it all politely Arty is more used to Soap giving her knicker elastic a "Ping"
![]() That bit she knows what happens L--Glad you is back,Fizz checked it out and it wasn't at the Org end Last edited by Dicky Ticker; 13-01-10 at 10:04 AM. |
#13 |
I do apologise for my rash assumption that everyone who used the internet knew a little bit about computers/networking etc.
So, every device on the internet has an address. This is called the IPAddress and is in the form of xxx.xxx.xxx.xxx, where each xxx is a number between 1 and 254. the range of numbers indicates a class and each network provider has been allocated one or more networks and the right to then allocated sub numbers on that network to their users. The ipaddress is not easily usable for humans. So we use URLs (network names). They are structured so that their resolution to an address is easy/quick. This resolution is performed by Domain Network Services or DNS. forums.sv650.org resolves to 79.123.35.161. Which would you rather remember? Ping indicates how quickly the internet can be navigated for one computer to talk to the next. However, you may want to know (Particularly when you are experiencing problems) how quick each network segment is that you are using. So for my home PC E:\Documents and Settings\tjw>tracert forums.sv650.orgThe above timings are taken by the tracert command pinging each intermediate device. However, you may have noticed that the last node is not forums.sv50.org. That is because the this url is virtual, as in it is one of many names hosted on this server and it is the job of the web server to send you to the right web base based on information contained in the request. Command windows vary depending upon what operating system you are using. On a windows box use start ->run and enter cmd. You will then get a black box in which you can enter quaint old commands like people used to do before graphical user interfaces became available. out of interest, do the above and enter "ipconfig" without the quotes. This will show you that your pc has an ipaddress assigned by your network provider. Whilst there type "ping forums.sv650.org" and that should indicate how quickly you can navigate the network to the org.
Not Grumpy, opinionated. Last edited by timwilky; 13-01-10 at 10:52 AM. |
#14 | |
You are one computer, the back wall of the cave is the other computer. You are in one location, the back wall of the cave is in another, these are your IP Addresses. Your voice is the "ping" Each wall your voice bounces off on it's way to the back of the cave is a "hop" The list of which walls your voice bounced off on it's way to the back of the cave is the "Trace Route" (tracert) The "command window" is your voice box, taking instructions from your brain to make a noise. Clear as mud? ![]() Last edited by -Ralph-; 13-01-10 at 11:00 AM. |
#15 |
The Sick Man
I just never changed the RDNS on that IP
![]() ping mail.wenn.com, you will see its actualy diffrent IP anyway The forums are most definatly a seperate system of its own, but virtulised. Gives away who i work for ![]() Should not show a ping on the last hop, i think i forgot and left ping turned on to that IP mmm i should turn it off me think
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#16 | |
Also many companies host 100's, if not 1000's of websites on one IP address. So a machine could say it is server.internetcompany.com but also be www.sv650.org, www.ilovekawasakis.com and www.hondalover.com You can safely ignore pings. To be honest, I'm surprised you are seeing them on your computer. Most setups nowadays (routers running nat) also have a firewall module and will either reply or block them it's self and not pass it onto the computer unless specifically told to. Dan |
Computer Question | 600+ | Idle Banter | 8 | 26-08-08 04:24 PM |
computer question | maff | Idle Banter | 9 | 15-07-08 06:02 PM |
question for the computer experts | kwak zzr | Idle Banter | 10 | 04-06-08 09:09 PM |
How do i... computer/xbox360 question | fraser01 | Idle Banter | 7 | 07-06-07 08:21 AM |
