Old 21-01-10, 11:00 PM   #11
EssexDave
Default Re: Question for you law lot.
Yes very thankful Ed.
I didn't want to repost and make it look like a shameless bump!
She says thanks for the advice too. (to everyone)
Old 22-01-10, 01:53 PM   #12
blue curvy jester
Originally Posted by Stig_Of_The_Dump View Post
I think the general rule of two lane roundabouts. If the turning required is 180 degrees or less, you should be in the left lane. More than this and you should be in the right. Once you have passed the last exit before the one you want, you should indicate and move into the left lane. This is however not set in stone. Local road markings may just indicate otherwise and obviously these should be followed. There is a roundabout on the A4 heading into Newbury from the motorway which only has 4 exits. All exits are 90 degrees from each other, but the left lane clearly indicates is for use only if you are taking the first exit from the roundabout. The amount of times I have been nearly knocked off my bike by other road users using the left lane but going straight on is unreal.
Stig this is ongoing argument i have with some of the people in work
I belive that the scenario you have above is what was taught until the 90's , and still applies on roundabouts where you approach as a single carrigeway ( even if it splits to 2 at the roundabout) going onto a single carrageway, or a single going onto dual or a dual going onto a single,
The problem happened post 90's where extra rules brought in say if its dual onto dual then either lane is usable regardless of weather the junction is past 180 degrees or not (as in coming off a motorway and taking the 3rd junction onto a dual carrageway , which is at 270 degrees from the entry point onto the roundabout)
We have a lot of these in Cardiff and they can be fuggin dangerous
they are fine as long as the car in the left lane says in the left lane and goes round the roundabout and down the left lane and the car in the right lane does the same,
but what tends to happen is that you get a lorry in the left wanting to go further round than the car in the right lane and casues all sorts of ****, or someone following the above rules and trying to get into the left lane after 180 degrees with no space.
To SV or Not to SV that is the question! Old Git Bikes - Talk & Issues 20 15-02-09 06:41 PM
car rad question Wideboy Idle Banter 5 15-01-09 09:27 PM
New SV question robbills Bikes - Talk & Issues 12 07-01-09 09:23 AM
NIP question oxfordgti6 Bikes - Talk & Issues 9 19-05-05 04:54 PM
K5 question. Rickster SV Talk, Tuning & Tweaking 4 04-03-05 09:14 PM
