Old 27-01-10, 09:12 PM   #11
SoulKiss
SoulKiss's Avatar
Default Re: TV as PC monitor
if the telly had a 15-pin D-sub connector, just use that.
Old 27-01-10, 09:38 PM   #12
fastdruid
fastdruid's Avatar
I play TV through a PC which is connected via DVI to my LCD TV
Works great even when got a desktop rather than MythTV.
Druid
Old 27-01-10, 10:01 PM   #13
wyrdness
Should work very well. 1080p is very high res 1900x1200 (off top of my head) so will look great from anything over about a foot away...
HTH
1080p is 1920x1080 hence the name.
Old 27-01-10, 11:55 PM   #14
tigersaw
tigersaw's Avatar
Many thanks for all the replies, seems its a good use for the spare telly then. I'm going to buy a new pc anyway, best way to get windows 7 and I have a copy of office enterprise I didn't want to waste the license on my current pc.
If someone using a HDMI TV setup could just look at the display settings property window and confirm the resolution that would be great.
Old 28-01-10, 08:37 AM   #15
wyrdness
See my post above for the resolution of a full hd 1080p TV.
Old 28-01-10, 08:53 AM   #16
tigersaw
tigersaw's Avatar
I'd just like someone to check that is the resolution that the PC is outputing at, and not the display making something else fit, such as 1920x1200 , 1920x1080, or even something lower than 1080p standard which is being upscaled
Old 28-01-10, 09:02 AM   #17
wyrdness
You set your PC to the native resolution of the TV. If you've got a full HD TV that is 1920x1080 then you set the PC display properties to 1920x1080. Simples, no?
For example I am using an HD TV as a monitor here, that has a resolution of 1440x900 pixels, so I've set the display properties in Windows to 1440x900.
Old 28-01-10, 09:17 AM   #18
tigersaw
tigersaw's Avatar
OK, I see.
Its just I plugged the girlfriends laptop with HDMI onto my TV once, it never gave a choice, just set itself up. Laptops gone now, so cant repeat the experiment.
Old 31-01-10, 11:14 PM   #19
tigersaw
tigersaw's Avatar
so, if I bought one of these leads:
http://www.esave2day.com/product/hdmitodvi-2m/
I could hook up my TV?
I dont have 1920x1080 as a resolution selection, my gfx is a gforce 7300 LE - which is not HDCP compliant (whatever thats all about), could I get the right drivers and make it work?
Old 31-01-10, 11:29 PM   #20
-Ralph-
Correct on the lead, subject to HDCP problems.
Most modern gfx detect the resolution capability of the attached monitor and that is the highest you can set. You may find that when you plug in your 1080p TV and select it at the monitor, you can then select 1920x1080 as the resolution. NVidia's website says about the 7300
Single-Link DVI Support
Able to drive the industry’s largest and highest resolution flat-panel displays up to and including 1900x1200. May vary by model.
so is the LE one of those varying models? Don't know.
I think most TV's have a non HDCP HDMI socket, so if you card is also non-compliant, the TV shouldn't look for an authenticated pair and so you shouldn't have the problem. I am making assumptions here though, I don't know enough about it to tell you for sure.
17" CRT Monitor metalmonkey Idle Banter 0 05-02-09 11:11 PM
I need a TFT monitor metalmonkey Idle Banter 2 24-04-08 03:20 PM
i got me a new monitor...... but hovis Idle Banter 27 25-01-08 05:40 PM
monitor........ which one? hovis Idle Banter 25 30-12-07 07:10 PM
PC/monitor help hovis Idle Banter 9 04-11-07 08:54 AM
