Old 04-02-10, 02:04 PM   #11
Ceebl
Default Re: Front brake
Originally Posted by ridelikeaturtle View Post
Pay attention to the caliper sliders too. They can get sticky; clean them out and replace w/new grease.
I'm sure there are threads on this sort of thing, see what the Search button reveals...
Here you go: http://forums.sv650.org/showthread.p...ticky+calipers
+100000000
my front brakes where sticky and I couldn't igure out why. Where the slide goes into the calliper itself had all grown up with corrosion, remove all of it or itl keep happenin! If the bike is used in the wet alot I guarantee this will b a major factor. Polish out and grease up!!!
Old 04-02-10, 02:10 PM   #12
speedplay
Default Re: Front brake sticking.
Have you got somewhere to put a shed to keep your bike in?
If I remember rightly you store it outside dont you?
Storing it dry would help cut out all the little niggles like this
Old 04-02-10, 02:24 PM   #13
SUPERSTARDJ01
Yeah I do but it's under cover in a carport and under a cover, I have no way of keeping it in a shed unfortunately.
Old 04-02-10, 02:28 PM   #14
speedplay
What about blanking off the back of the carport.
Even under a cover, bikes tend to get damp
Old 04-02-10, 02:40 PM   #15
SUPERSTARDJ01
Is this it?
http://www.mcnninjas.co.uk/forum/ind...?topic=75767.0
http://www.youtube.com/watch?v=_6Hphm1bMPM
Old 04-02-10, 04:26 PM   #16
That MCN ninjas guide is ok.
I do pretty much that, but never use brake fluid as a lubricant. I use a bit more red rubber grease on the caliper half seal, copper slip on the caliper half bolts and a very sparing amount on the bleed nipple threads.
Old 06-02-10, 03:41 PM   #17
Taipan
Taipan's Avatar
I noticed as I stopped at the lights the other day my bike "bit" as I stopped. Its slowly got worse. I took the calipers off to have a look today and despite cleaning them literally the other week they look like they haven't been touched in years! Dont even ask about the recently cleaned air filter! Winter weather and the salty roads really takes its toll.
Old 09-02-10, 01:50 PM   #18
SUPERSTARDJ01
is there a way of doing a partial service on them? or cheap way i.e just buying the rubber grease, have all the tools, is it necessary to use compressed air?
Old 09-02-10, 02:10 PM   #19
Taipan
Taipan's Avatar
If you can pump the pistons out as far as possible and if neccessary holding one back a bit so they come out equally, you may be able to get them out with piston pliers like the ones below.
They can be a sod to bleed after overhauling. So try filling the calipers with fluid before re-attaching and if need be remove bleed nipple to pump fluid into and out of the caliper as well. Once its clearly coming out fit the nipple and bleed as normal.
http://cgi.ebay.co.uk/Brake-piston-r...item2eaac2b293
Old 09-02-10, 02:21 PM   #20
Only special tool you need is a G clamp.
Front brake sticking. wilky007 SV Talk, Tuning & Tweaking 5 13-07-09 10:34 PM
Brake light switch sticking on with front brake rick0361 SV Talk, Tuning & Tweaking 6 11-06-09 06:20 PM
brake lights sticking on evertheoptimist SV Talk, Tuning & Tweaking 18 30-03-09 01:17 PM
Brake pedal sticking. daveb SV Talk, Tuning & Tweaking 11 13-02-09 02:54 PM
Sticking, Jerky front brake. - FIX Mark_h SV Talk, Tuning & Tweaking 5 13-12-06 01:36 PM
