Old 07-02-10, 04:48 PM   #11
Seggons
Default Re: The Right Or Wrong Way.
Thanks everyone for your comments. This case is well and truly solved, Thanks.
Old 07-02-10, 04:50 PM   #12
Yeah right
Old 07-02-10, 04:50 PM   #13
speedplay
Originally Posted by Filipe M. View Post
You mean she doesn't gain speed when you apply pressure on the brakes?
You need wd40 on the discs in order for them to do that
Old 07-02-10, 06:40 PM   #14
suicidesam
Posh Grooved discs are sometimes handed so the cuts slope back or forward to the outside on both discs, cheaper ones are a pair with the same pattern.. end up with one pointing forward, one backwards! What way does the N/S disc groove point?
I've ran all sorts of grooved/drilled/wavey discs on cars in the past, Tarrox, Black Diamond, ebc... none have came with a diagram saying they must be fitted any set direction. They are only there to stop the pads glazing under heavy use, dont think thats going to be the case though
What was he doing wrong??? gruntygiggles Idle Banter 245 28-07-10 02:24 PM
Was I in the wrong? jamesterror Idle Banter 47 05-09-09 07:13 PM
What was She doing wrong??? Dave20046 Idle Banter 146 15-04-09 01:26 PM
When wearing high heels was wrong, so wrong... Razor Idle Banter 6 03-06-06 08:51 AM
Wrong Construction wrong colour . amarko5 Bodywork 12 30-10-04 03:23 PM
