Old 12-02-10, 07:31 PM   #11
Durbs
Default Re: Rubbish GSX-R disks
Originally Posted by Alpinestarhero View Post
Wire wool will remove the corrosion, but wont prevent it from returning. The only way to do that is to apply a coating too the layer to prevent air and salt from reaching it, to avoid the electrochemical process.
But that would be a silly thing to do on brake discs...
Suzuki have done that with the rear disks where the anti corrosion coating reaches the braking surface but seem to have omitted that on the front ones.
Old 12-02-10, 07:45 PM   #12
scottjames
durbs please pm will the sussessfulnes of your letter to suzuki as im half tempted to do this myself. if i have time im going to go to my dealer to mo to get the obligatory "NO". then a letter to suzuki. scott
Old 12-02-10, 08:53 PM   #13
Alpinestarhero
Its for looks. Its only some sort of paint on the rear disc...you could probably paint it yourself if you are carefull
Old 13-02-10, 12:27 AM   #14
Or even if you're not, any paint will get scrubbed off the friction surface
Old 13-02-10, 02:01 AM   #15
'not fit for purpose' and 'could turn into a danger under breaking' spring to mind.
ooohhh and suzuki uk will just say take it to your nearest dealer.
Old 13-02-10, 07:27 AM   #16
muffles
Odd, I have an 08 750, I will check my brake discs later today but pretty sure it's fine and not like that. And I've had it coming up to 2 years now! (albeit, I don't take it out in the wet if I can help it, as I have 2 bikes )
Old 13-02-10, 01:24 PM   #17
Been out today and looked at all our bikes.
Suzy's discs are defo not like that(EBC). Dave well his are a little more dubious but then its ridden in anything(Stealth waveys)
and Pegs 2008 zzr1400 with 23000 miles put on it since July last year.....aren't like that(slight rust if that), but hey big difference in mileage, and its ridden everywhere, and kept outside!
Is it possible the bobbin thingies(them round things holding the disc on the carrier) are inferior quality and leaking out corrosion into the disc itself, we noticed its only inbetween each bobbin thingy.
Old 13-02-10, 02:07 PM   #18
fastdruid
fastdruid's Avatar
My ex-hayabusa frontend was never that bad even after ~25k (plus what ever the bike it came from had done) and that was ridden through all weathers and barely cleaned.
This is the best I have of the disks but even then you can see they aren't rusty (unlike lots of the bolts!)
Druid
Old 13-02-10, 02:18 PM   #19
Alpinestarhero
I noticed a little bit of rust around the buttons on the discs today
only a litle bit mind.
Rubbish Monday! ManxMatt34 Idle Banter 0 31-08-09 09:52 AM
AOL is rubbish! Milky Bar Kid Idle Banter 38 01-04-09 11:11 AM
Michelin's - see they are rubbish! Blue_SV650S Bikes - Talk & Issues 37 20-08-08 07:37 AM
football is Rubbish Frank Idle Banter 85 09-05-08 05:17 PM
Is all TV now rubbish ? tricky Idle Banter 40 13-04-07 08:39 AM
