#11 |
learn to read the road. Look for the vanishing point I.e what you can see, when the vanishing point is moving away from you I.e the corner is opening out and your view of what is in front of you is expanding then that is the time to roll the throttle on gently and smoothly does it no big handfulls. Only apply the throttle when you know you won't have to roll it off, so roll it on and drive the bike out of the corner, 5000 rpm is a good place to be to do this. Remeber look where you want the bike to go so look through the corner at the exit of it.
#12 |
+1 am Fizzmeister
#13 |
+1 the limits of visibility and picking up visual information is FAR more important for safe and rapid road riding than the absolute limits of grip.
But, all you need to do is pick up the throttle earlier by the sounds of it. Turn in with a slight amount of gas on, it settles the bike nicely, then as you can see the exit is clear gently wind it on. Just look at your exit and the bike will sit itself up as you accelerate out. Be smooth with the throttle, get your toes up on the pegs and relax your arms. Grip the tank with your knees. If you are weighting the bars, duck footed with your nuts on the tank then the bike will feel numb.
#14 |
If you're on a decent dry road and the tyre is warm, you'll have trouble getting it to slip at all unless you're using some crappy chinese remould.
#15 |
+1 to Fizz and YC. This time of year though you only want a smidge of throttle until its upright.
For me I'm back on the throttle to 'catch' the bike just before max lean, only a smidge but enough to stop it falling any further then wind it on as appropriate to the road/corner. How many rpms depends on corner and conditions, fwiw if attempting any kind of speed I go in with lots of revs in slippery conditions[1], its more responsive and should it step out it hits the limiter before it gets too sideways. ![]() Druid [1] I've had some very fun wet rides.
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#16 |
usualy just after or on the apex (depending on corner) but only in the dry usualy keep the throttle nutral in the wet or adding just abit of power... but im no expert
#17 | |
![]() Pickup drill: Note. This is not really a novice thing. If you're a muppet and highside trying - not my fault! ![]() You should be slowly rolling on the gas as soon as possible in the corner. As you start to pick the bike up, consciously countersteer to bring the bike more upright WHILE rolling on the gas at the same time but don't stop hanging off the bike i.e keep your weight to the inside. Biggest fear on rolling on the gas on the corner exit is losing traction and highsiding. By actively picking the bike up, you are ready to catch the slide if it occurs. You also get much better drive out. After a certain point, you won't lose the rear-end anymore but will Gary McCoy it out of the corner instead! ![]() Ok - most people won't get that extreme/aggressive with the throttle, but still applying the technique can give you more confidence and drive exiting a corner. |
#18 |
+1 with Luke. If you never learn to ride with a square tyre in the greasy winter months then you'll never be able to ride efficiently in the winter months on a squared off tyre (or in other words, the real world
![]() The only thing to add to Luke post I can think of is to let your bum move over first as you counter steer. That way the bike returns to upright sooner and your body follows it. So, from leant over you countersteer and the bike starts to rise, you hinge in the middle and your bike moves to vertical taking your but cheeks with it and your body follows. That way your bike is as vertical as possible at all times. Oh and Be smooth. C Last edited by Berlin; 18-02-10 at 08:07 AM. |
#19 | |
I had problems getting into corners when I was starting riding, and former member Baph told me to go in like a pussy cat, out like a tiger. The idea is that if you go in slow, the bike remains composed and settled, allowing you to gently feed on power. As you feed on the power, the bike will sit itself up ![]() See: Dani Pedrosa, he does this so obviously Last edited by Alpinestarhero; 18-02-10 at 07:50 AM. |
men straightening their hair? | malks | Idle Banter | 96 | 28-08-08 08:12 AM |
Straightening bars? | phil24_7 | SV Talk, Tuning & Tweaking | 4 | 02-03-08 06:42 PM |
Frame straightening checks | riktherider | SV Talk, Tuning & Tweaking | 0 | 04-05-07 02:54 PM |
Brake Disk Straightening | TSM | Bikes - Talk & Issues | 6 | 05-06-06 11:26 AM |
wheel needs straightening! | socommk23 | SV Talk, Tuning & Tweaking | 16 | 17-05-06 09:07 AM |
