Old 24-02-10, 07:51 PM   #11
Traceur-Sham
Default Re: Headlight Upgrade
I just fitted an H4 Hi/lo HID kit to my K9 SV650 Sport. Had to extend the power lead to battery since it was a bit short. I managed to tuck all the cables and ballasts inside the front fairing.
Light is considerably brighter, especially high beam. Haven't been flashed yet by other road users so i'm assuming the beam trajectory is correct.
Problem: I grounded the two negative leads to a bolt on my clutch lever which causes the lights to flicker whenever I touch the clutch lever/change gear. Sometimes, ALL my lights cut out and have to restart the bike.
I'll need to find a better grounding point on the main frame, otherwise it's gunna be a pain in the ass.
Old 24-02-10, 08:15 PM   #12
Yeah ground directly to the frame or front subframe, grounding anything to the bars/front end is always dodgy because you can't guarantee conductivity through the head bearings.
Old 24-02-10, 08:55 PM   #13
disco
Originally Posted by AnotherFool View Post
Yup, y'all got me, I'm American.
Thank you all for the replies, you answered my question spot on.
As far as the dealership... They are the only one with a service department within 3 hours drive of me...
sounds like the perfect excuse for a decent ride - if you need an excuse.
disco is offline   Reply With Quote
Old 25-02-10, 09:32 AM   #14
Bluepete
Bluepete's Avatar
I have been told... that if yo go to HIDS4U and at the payment page enter "strathy" without the inverted commas into the discount code box, the kits become even better value for money!
Pete
Old 25-02-10, 09:27 PM   #15
SUPERSTARDJ01
Pete
This is true u get a quatar off.
Old 26-02-10, 12:27 PM   #16
Ceebl
My k1 half faired has 'imported' lights, ie the beam sweeps the wrong way, dipped beam is the clutch side bulb with a lens and full beam is the throttle side bulb, is this still the same set up as a normal curvy? Don't wana buy an HID kit if it runs both bulbs all the time! Not sure how curvy lights are meant to work! Haha
Old 26-02-10, 12:29 PM   #17
fastdruid
fastdruid's Avatar
No that's not normal, well not normal for the UK anyway, UK curvy 'S' models light both bulbs on dip and both on main.
If you replace the bulbs though it would work exactly the same, you'd have to change the wiring to make a difference.
Druid
Old 26-02-10, 12:54 PM   #18
widget
the h.i.d4u website says its a single unit and bulb so i would need two for my k3 right?
Old 26-02-10, 01:43 PM   #19
fastdruid
fastdruid's Avatar
Depends on which k3 you have!
Druid
Old 26-02-10, 01:49 PM   #20
Taipan
Taipan's Avatar
Do any of these newer HID bulbs fit the naked headlight shell? IIRC the earlier ones were too long to go into a naked headlight?
Upgrade Headlight Bulbs, Which ones? cbay SV Talk, Tuning & Tweaking 39 27-01-10 01:03 PM
HID headlight upgrade - curvy GavinD SV Talk, Tuning & Tweaking 12 17-07-09 06:54 PM
Yet another curvey headlight upgrade question stewie SV Talk, Tuning & Tweaking 29 04-04-08 09:57 AM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
HEADLIGHT BULB UPGRADE SV650S csimmo SV Talk, Tuning & Tweaking 8 26-04-05 01:55 PM
