Old 07-04-10, 12:34 PM   #11
barwel1992
Default Re: HELP Please! Nitromors on plastic bath
it might not be the best idea but why not try a tiny bit of nitromoors on one of the stains ?
i
Old 07-04-10, 12:41 PM   #12
keith_d
keith_d's Avatar
Best I can suggest:
On an inconspicuous corner of the bath see if Nitromors will dissolve the plastic the bath is made from. If so you might be in some trouble because the paint is probably fused to the bath and you may have to sand smooth and repaint.
If not I'd consider using a spot of nitromors to soften the paint up again, then scraping it off with an old knife. Use kitchen towel dipped in nitromors to remove the last traces. (oh, and don't forget to wear gloves).
Keith.
Old 07-04-10, 02:30 PM   #13
Sudoxe
Vodka will fix that.
Take the bottle of Vodka, drink 1/2 of it and you won't be worried about the bath anymore...
Old 07-04-10, 02:34 PM   #14
Messie
The Teacer
Messie's Avatar
OK will try more nitromors. Homeopathic 'medicine' relies on treating like with like, so here goes
Old 07-04-10, 02:34 PM   #15
Messie
The Teacer
Messie's Avatar
Lol. That's the final plan!
Old 07-04-10, 02:49 PM   #16
PsychoCannon
worst worst case just get artistic and paint the entire bath, say it's a designer =p
Old 07-04-10, 02:54 PM   #17
What about brake fluid, its less agressive than nitromors at removing paint, takes longer so should be a bit milder, albeit never tried it on a bath.
Old 07-04-10, 02:55 PM   #18
Jayneflakes
Jayneflakes's Avatar
Genius idea... Problem solved.
Jayne you're a Pussy Magnet
Old 07-04-10, 02:55 PM   #19
zachl
put nitromors on a cotton wool pad, leave it on the paint, shud scrap off after a while, baths already ruined so cant make it worse
Old 07-04-10, 03:14 PM   #20
Messie
The Teacer
Messie's Avatar
Well that didn't work . Made the plastic go soft and I could scrape some paint off with a blade but it actually took the whole surface off. I'm giving up for today and will cheer myself up by arranging the nice new fluffy towels and bathmats instead. In the morning I'll go and find another type of paint stripper that might shift the paint but leave the plastic.
It it really possible to paint a bath though? A plastic one? I know you can paint new enamel onto an enamel one, but plastic? If so I might give it a go.
What plastic are the plastic bits made out of? Mark_h SV Talk, Tuning & Tweaking 3 24-03-08 08:32 PM
Recomend me a bath mat(Yes seriously) Viney Idle Banter 16 08-10-07 05:05 PM
Spider In The Bath Lissa Idle Banter 65 12-07-07 01:27 PM
Bath tub test cuffy Idle Banter 11 23-08-06 12:18 PM
Plastic / Fairing Repair (Plastic Welding) Solution MattP SV Talk, Tuning & Tweaking 2 29-06-06 04:14 PM
