#11 | |
I often do this and think "well he's just about doing 60mph, it's a 60 limit, I was only doing 5 - 10 mph more than him anyway, so I'm happy enough to sit behind him"
#12 |
There's nothing wrong with that approach, I frequently like to chill out and knock a bit off the pace, but not what I'm on an advanced test and expected to demonstrate my observation, anticipation and planning skills. It would be no good saying to the examiner, "well I could have done it if i wanted to". They will be examining you on what you did, not on what you wanted to do!
#13 | |
I guess what a good observer needs to say is
"there's nothing wrong with that, not overtaking doesn't mean that you are not of the standard to pass an advanced test, and after you've passed the test you do what you like, but for the purposes of the test you will need to demonstrate in a short space of time that you are capable of seizing overtake opportunities, so you need to practice swift and safe overtakes on your observed rides" There does seem to be some advanced training going on, where overtakes are seen as mandatory, Quote:
#14 |
Unfortunately its not that black and white. Taking your 56mph example, to stay within the speed limit you only have 4mph to pass the vehicle, assuming 150yds to make a safe overtake that would take well over a minute.
The question then becomes given the road, weather, traffic, visibility would it be safe to be on the wrong side of the road for over a minute given that during that time you would have travelled a mile along said road (unless my math is way off) This could be a perfectly safe overtake given the right circumstances but then you have to consider the vehicle. if its 64 yearold lady driving to church then you can be fairly sure her speed will not alter, ifi its 2 baseball cap wearing neds in a pimped out corsa you can reasonably expect them to accelerate as you overtake as you would be threatening their manhood. (apologies if stereotypes offend) To answer the op, the object is to SAFELY make progress. The aim is to equip you with the tools to reach the decision as to which overtake is safe. If an advanced course expects you to adhere to the speed limit (they do) then you cannot be expected to overtake a vehicle doing 56 in a 60 unless the planets align. For me any advanced training provides you with the tools to apply ideas and practices to your style of riding in a way which hopefully both improves it and increases your safety. |
#15 | ||||||||
Trinity
Siting behind a car is putting yourself in conflict with a hazard on the road, you don't know how erratic their driving could become. If you overtake & then sit at 60 mph while the other car continues at 56, then you will be moving away from the hazard at over 100 meters a minute, so after 5 mins you'll be half a km away, I like the sound of that instead of remaining 2 seconds away from them. (If you do the speed limit of 50 while the other car was doing 45 then it would be over 150 meters extra clearance between you per minute)Well, I would say minimise all danger - if you want to remove it, stay at home
#16 |
Trinity
Sorry J. I did want to answer your original qu. instead of getting carried away with the other replies.
The first thing to note is that speedos are inaccurate, so you need to learn what your own is like so that you can truly know what you are allowed. So compare with a sat nav if possible, or other bikes if they have been able to asses how accurate theirs are. Of course speed limits are a limit and not a target and they do not need to be achieved unless conditions allow, but if conditions do allow, then yes as an advanced rider, you will be expected to demonstrate that you are capable of riding up to the speed limits, and that will generally mean you need to make progress. If you cross the line (wherever that line is) and start riding aggressively then I wouldn't expect you to pass the IAM test while doing so. HTH or let me know ![]() |
#17 |
I'm with Ginger. If the vehicle is doing 'just' under a 60 speed limit and I was going to overtake I would prob end up doing 70 at the end because I like to spend the least amount of time as possible in the opposite lane. If the circumstances allow me the end up doing 70, or if I'm on a 'spirited' ride, then I'll happily go for it. However if I'm in no rush, or the weather/traffic/presence of police mean that it's not a good idea then I'll back off. I don't see the need to overtake something because its in front of me.
I use the same policy with filtering, especially on the motorway. If the traffics doing 40 or more then I don't bother. |
#18 |
An IAM examiner will be looking for safe, smooth and systematic riding with sufficient progress for you to be able to demonstrate your observation, anticipation and planning skills. The IAM's advice is that you will be expected to ride up to the speed limit if conditions and circumstances allow, but they do not expect you to pass their test if you break the limits. Personally I've never known anybody even come close to failing an IAM test for excess speed, generally it is the complete opposite. They are so concerned about making a mistake they slow everything down and the ride completely loses it's edge.
An advanced rider oozes confidence, and that won't come overnight. It's something you really need to work on and the way to do it is to continually assess what you are doing and be constructive in your self criticism. Good luck. |
#19 | ||
I'm not a sheep and I make my own decisions when riding or driving and always will do, I'm not following a hard and fast rule for the rest of my life because the IAM says I should. I'd follow a rule to get through a test, but if I don't agree with it then after that it's out the window. Quote:
Whether or not your happy to sit behind is just a state of mind, and has a lot to do with levels of patience, which appears to change in your case depending upon who is driving the vehicle in front. I never find driving or riding "stressful" per se, unless someone starts road raging on me, but there are more and less relaxed journeys. The only time sitting behind somebody has me "stressed" (although stressed is too strong a word), is if I want to overtake them and there is no opportunity to do so for a considerable distance. If I don't want to overtake them, sitting behind them causes me no stress at all. I'll be happy sitting behind them if I feel they are travelling at an appropriate speed for the road, conditions and speed limit. Last edited by -Ralph-; 29-04-10 at 12:25 PM. |
#20 | ||||
Trinity
Advanced Riding Courses | falc | Guildford Massive | 19 | 13-02-14 08:02 PM |
Advanced riding stuff | Mark_h | Thames Valley | 7 | 19-09-08 12:49 AM |
Advanced Police Riding | SoulKiss | Idle Banter | 15 | 06-06-08 10:15 PM |
Advanced riding | Mark_h | Thames Valley | 42 | 07-03-08 12:09 PM |
Advanced riding – braking | Blue_SV650S | Bikes - Talk & Issues | 57 | 27-10-07 12:29 PM |
