#11 | |
Hahaha, it seems I'm not alone... This guy describes the exact same senario. http://www.diydoctor.org.uk/forums/viewtopic.php?t=2340 From that, I worked out the handles are probably made by Urfic, so went to their site and found a very similar if not identical design handle like this... ![]() As you can see the rose has a cover that hides the bold heads. I've just emailed them to see what they can do for me. ![]() |
#12 |
Quiff, it's a case of "you scratch my back, i scratch yours".
If you can find me these bolts, I could ride down to yours and supply a ridiculously loud Tuono to annoy your narky neighbour at the BBQ! ![]() |
#13 | |
Probably named something like "door opening device,through fixing retainer" I think its something like these that your after :- ![]() |
#14 |
If you are just after the screw and not the fitting with the internal thread, just go to an electrical wholesalers and ask for some 'brass M4 Screws'. Thats if it is a 4mm thread. I use them all the time. They arent a countersunk head but do have quite a small head that you could make fit.
#15 |
I could however send you some if you like? I have a load at work, i'd just need to get a stamp and envelope..
#16 |
Oh my, thats the very babies! Thankyou, thankyou, thankyou speedplay!!!!
![]() Did you just take your door apart? If so, i apologise for destroying your house through the power of the internet, lol! Are you sure you wont need them? They don't seem to be readily available so I wouldn't want you to be stuck without them sometime later. I'll need quite a few too, maybe 30? |
#17 |
#18 |
After a good search which I gave up on twice... I found this:
http://www.sdslondon.co.uk/connectors.html |
#19 |
Any kitcar builders on here? | Paul the 6th | Idle Banter | 31 | 03-12-08 01:29 PM |
Any builders on here? | Camel | Idle Banter | 25 | 28-05-08 09:58 PM |
The three little cowboy builders | gettin2dizzy | Idle Banter | 7 | 28-01-08 01:11 PM |
Any builders on the site ? | stewie | Idle Banter | 14 | 19-10-07 01:46 PM |
One for the builders/tilers | Tris | Idle Banter | 5 | 10-05-07 09:06 PM |
