Old 04-07-10, 04:47 PM   #11
Default Re: Plumbers... Help!
Stop using it as a toilet
Old 04-07-10, 04:56 PM   #12
phil24_7
Originally Posted by Messie View Post
Is it a general damp type of smell or a more yucky something's rotten type of smell. I've had both and a helpful plumber explained things to me.
If it's a damp smell, there's a leak somewhere that needs to be found and fixed. If it's a rotten smell it's more often than not something blocking the exit of dirty water. It doesn't have to be really dirty water, just from the shower is called dirty water. I was advised to try a strong drain/plughole clearing stuff first before calling in the experts or ripping up floorboard. I used good old fashioned soda chrystals rather than an expensive brand of stuff, and sure enough the blockage was cleared and smell went away.
Got to be the cheapest first option for trying to fix it?
No blockage, all water drains well, just after a period of inactivity, the shower cubicle smells of sh*t! It all points to a leak in the trap to be honest, and after my investigation of the trap, it's seems like the most logial explanation.
Hopefully the problem is now sorted as the rubber seal in the trap did not appear to be seated correctly.
Old 04-07-10, 04:57 PM   #13
phil24_7
Is there water when you look down the waste, if there is, you have a trap
If there is no water, you dont have a trap and obviously its the water that stops the smells coming back up from the drain.
I do have a trap, and I think it may have been leaking. I believe it is all sorted now...hopefully!
Old 04-07-10, 05:00 PM   #14
caz650s
Originally Posted by Razor View Post
check the trap isn't full of hair and gunge
Old 04-07-10, 05:00 PM   #15
you cant be having stinks in the bathroom can you
Old 04-07-10, 05:01 PM   #16
Razor
get some microban and spray the area, last thing you want is mould under the shower,stink will never go away
Old 04-07-10, 09:34 PM   #17
phil24_7
OK will do, cheers.
.Org Plumbers? Dave20046 Idle Banter 213 09-04-12 08:51 PM
plumbers around middlesbrough nik_nunez Pennine Massive 2 04-06-10 08:22 PM
Any Plumbers? Help Please. Scoobs Idle Banter 16 05-01-10 10:27 AM
Any plumbers on here? ukgooner Idle Banter 15 27-04-08 11:50 AM
Plumbers help with my new bathroom furrybean Idle Banter 27 06-02-07 09:23 PM
