Old 26-07-10, 06:06 PM   #11
Default Re: Baffled..
that what i thought!
mine doesnt sound right and i know that the engine and box are fine
the exhaust sounds like it is trying to push something out the way
Old 26-07-10, 07:26 PM   #12
Jordy
I have a Scorpion exhaust and have experimented myself, didn't notice a difference... I love the sound so leave it out.
Old 26-07-10, 08:31 PM   #13
Stripping out the baffle will change the back pressure as the end can in effect becomes a expansion chamber (like on a 2 stroke) but should not have an adverse effect.
No resonating shape, no stinger to set up return pressure waves... just a pipe. How's that an expansion chamber?
Old 26-07-10, 08:37 PM   #14
bad analogy chris. Acoustic would have been better
Old 26-07-10, 08:55 PM   #15
my stock exhaust's baffle has degraded with age and is effecting overall back pressure so requires removing or replaced!
I really doubt it. There would have to be serious running issues with the rest of the bike to coke one up enough to do that.
Old 26-07-10, 09:05 PM   #16
sounds like a wet fart in the bath the exhaust. Needs replaced for a better end can
Old 26-07-10, 09:08 PM   #17
Any standard can does. If you think this is causing a running issue then you are either fooling yourself or there's something else going on.
Old 26-07-10, 09:15 PM   #18
probably the former as the bikes just been properly serviced.
Old 26-07-10, 09:25 PM   #19
Default Re: Will fitting a baffle affect performance?
Come down here, I have a scruffy but very loud and very straight-through stubby can you can have, £30 fitted.
Old 26-07-10, 09:28 PM   #20
whens best?
tis may take you up on that
Fitting a baffle: Question thor Bikes - Talk & Issues 1 06-11-09 12:10 PM
How does the new tax rate affect you? gettin2dizzy Idle Banter 46 08-04-08 05:43 AM
The Budget - how will it affect you the_lone_wolf Idle Banter 40 13-03-08 04:36 PM
Alarm - Will it affect my warranty? Defender SV Talk, Tuning & Tweaking 9 19-01-08 10:27 PM
Fitting Blue Flame Evo Baffle JakeRS SV Talk, Tuning & Tweaking 6 23-04-05 10:20 AM
