Old 15-09-10, 02:57 PM   #11
Joeskeppi
Default Re: Jumping out of 2nd back to neutral.
Does it on mine sometimes (2009, 4k miles) unless you smash the granny out of the shifter to put it into 2nd.
Old 15-09-10, 04:26 PM   #12
I'd advise you to actually look at how a gearbox works and realise that banging anyones granny will not make 2 pieces of steel slide into place if it bends the selector forks...
Old 15-09-10, 06:15 PM   #13
Daywalker
Daywalker's Avatar
Originally Posted by breakz187 View Post
when i said lever, i actually meant the the foot lever for the gear box.
Yep try adjusting your gear rod lever down slightly 4mm/5mm with your riding boots on work for mine ok...........
Daywalker is offline   Reply With Quote
Old 15-09-10, 07:50 PM   #14
coxxy
Hope this helps:
Since our change of detent arm, star and spring from stock set up to this:
http://www.factorypro.com/products/F...Pro_shift.html
we have had very few false neutrals across 1st - neutral to 2nd and up and down the box. Prior to this upgrade, two false gears at high revs cost us one serious accident and one possible race win. If the bike is 2004 or older it could be a good investment to fit one but dont expect change from £200. It would definitely sharpen up all gear changing though. There are other things it could be as has been said. Position of lever to foot, gear shift link arm to gear shift rod position (should be at 90degrees), set up of clutch adjustment, bent push rod, poor lubrication. Rider errors ? but you seem to have had it a while....................
Old 15-09-10, 08:06 PM   #15
ryangarside
mine does it sometimes if i go from first to second without clutch, even if im not giving it some death. i can ride gently and go for 2nd with no clutch, it'll go into gear no problem, and wont jump out of gear till i pin it wide open. bit ierd really but i just ride round the problem if i use the clutch into 2nd its fine.
Old 15-09-10, 08:11 PM   #16
Originally Posted by coxxy View Post
Hope this helps:
www.factorypro.com/products/Factory_Pro_shift.html
retro fit parts from k5> bike is cheaper.
Old 15-09-10, 08:34 PM   #17
christopher
christopher's Avatar
Mine (K5) has jumped out a couple of times - in 18 months of having the bike - because I didn't move the foot lever all the way up... usually no matter how high the revs and no matter if I clutchless up change or not, it slips in nicely so long it's firm (awats smutty comments).
christopher is offline   Reply With Quote
Old 15-09-10, 10:24 PM   #18
ryangarside
awaits smutty comments? why would there be?
Old 15-09-10, 10:26 PM   #19
So long as his shaft is well lubricated
Old 16-09-10, 10:49 AM   #20
Joeskeppi
Tell that to Wayne Rooney.
Sarcasm detector not switched on, what I (obviously) meant was, make sure you shift fully.
Jumping speedo Mads_DK SV Talk, Tuning & Tweaking 6 11-07-10 09:43 AM
jumping out of gear AndyBrad SV Talk, Tuning & Tweaking 15 12-05-09 09:47 PM
Bike keeps jumping out of 2nd gear. jimmy-james Bikes - Talk & Issues 23 25-04-09 11:13 PM
jumping out of 2nd :-( The Laughing Assassin SV Talk, Tuning & Tweaking 10 24-06-08 12:27 PM
Cliff jumping! ClemsonSV Idle Banter 7 25-07-07 02:23 PM
