#11 | |
IMO good suspension is more important for road riding than track... it's only because you've not ridden a bike with working forks... the difference in stability and how quickly you can apply the brakes is mind boggling
#12 |
I have to admit Chris if yours are better than what I have now you are going to make a lot of money from SV owners
#13 |
So is it knackered head stock bearings that cause a clunk over bumps? ive noticed that if i hit a bit ov a pothole, even a minor one it tends to clunk..
Cheers |
#14 |
It can be but there is a clunk which is produced by the fork internals.
#15 |
Ah, so is this an SV specific thing or is there a few bikes out there with naturally clunky forks? not really ridden any other bikes so i wouldnt know.
Cheers |
#16 |
^ a few would do it, i think the bandit6 would do it as i think im write in saying the forks are the same type (damper rod)
all i know is before my RSV front end swap it would clunk, now it dosn't but there again it has all new head bearings as well. |
#17 | |
![]() These spinldly little 41mm beauties were better than my fully sorted K-teck "every possible thing in there" forks on the GSXR 600. But it'll be because Chris uses Undiluted Voodoo Specially imported from Jamaca, not that common or Garden stuff. ![]() And if he get his lathe going the new bike is itching to be converted too ![]() I got my springs from the same bloke you did Dan, Nice bloke and great set up! Nice little indutrial estate too. C Last edited by Berlin; 25-10-10 at 10:00 PM. |
#18 | |
![]() Sometimes heavier springs and the thicker oil shuts it up. It could quite possibly be part of the valve inside the fork banging closed or a bit of cavitation or something that the thicker oil prevents, or soaks up a bit so you can't hear it.
#19 | |
Ah so you nipped over to Sutton on Forest to get your gear. It is a really good set up and he knows his stuff. However I have volunteered myself as test pilot #2 as I am really intruigued about these forks. I never really appreciated how "good" good forks need to be until I really started pushing the SV. |
#20 |
Well if we both get them done, I can send you my settings and see how you get on with them. You might have to reduce them by 20% as mine will be for the track. at the very least, I'll be able to give you a base setting to work from.
C |
2nd Gen Naked to S front end conversion | Wonderfulness | SV Talk, Tuning & Tweaking | 5 | 12-01-19 07:39 PM |
GSX-R Front end conversion | phil24_7 | Photos | 268 | 06-06-13 12:34 PM |
GSXR front end conversion using SV front wheel | maviczap | SV Talk, Tuning & Tweaking | 24 | 13-03-10 02:06 PM |
Front end conversion | Bikerz | SV Talk, Tuning & Tweaking | 5 | 28-05-05 06:45 PM |
Rear/Front End Conversion | Bomber | SV Talk, Tuning & Tweaking | 3 | 06-05-05 09:15 AM |
