Old 04-11-10, 04:41 PM   #11
SV650Racer
Default Re: Slipper clutch
Slipper clutch....if you get one you wont want to ride without one again!.
Are you blipping the throttle when downshifting?. The SV has a lazy motor so doesnt need to be downshifted that many gears so you could try going down one less. Manually slipping the clutch out will also reduce the amount of lock from the rear but to be honest shouldnt be needed on the road.
Old 04-11-10, 06:17 PM   #12
kiwi_uk
Dude, get the sliper clutch. You will love it and it is great on or off track.....
Old 04-11-10, 11:39 PM   #13
SVGrandad
SVGrandad's Avatar
Default Re: Slipper clutch for SV?
My thou has a slipper clutch, so I am told. I have never felt it operate, and I know for a fact that it didnt stop the rear wheel locking up when trying to bump start it in first gear - and before any one says not to use first gear for bump starting, it was when a cold motor stalled on pulling away and there was only enough motion/time to try a quick clutch drop.
SV1000S K4, Hugger, Scottoiler. Lowers
SVGrandad is offline   Reply With Quote
Old 05-11-10, 01:26 AM   #14
no point to having one IMO. If you are good enough to need one, you are good enough to not have to ask us lot.
You were told wrong.
Old 05-11-10, 02:09 AM   #15
zadar
Which is perfect reason not to get one.
Old 05-11-10, 06:34 AM   #16
TazDaz
Nick, if it is locking easily when down shifting, you may want to review how you're changing down. It will happen occasionally if you're hooning and time or judge it wrong, but shouldn't be too often. Is it happening when you're going down multiple gears at once? Try going down one less if it is, or releasing the clutch a bit slower.
Old 05-11-10, 09:14 AM   #17
flymo
flymo's Avatar
spend your money on some track days and practice downshifting
Old 05-11-10, 09:22 AM   #18
toby_smith
Originally Posted by Nick_69 View Post
No dnt want to race in minitwins I just find that my rear locks easily when down shifting and it puts me off going into the corner
Spend some time learning to blip the throttle. Clutch in, change down gear, blip throttle, clutch out.
Once you've got the hang of it you'll do it everytime you change down without even realising it, it becomes second nature.
Old 05-11-10, 09:25 AM   #19
Paul the 6th
Paul the 6th's Avatar
buy a gsx-r...
Old 05-11-10, 09:34 AM   #20
Nick_69
Nick_69's Avatar
Yea it happens on multiple gear changes, may be its just a little bit of unexperience especially on the track
Was SV650S K9
Now GSXR 600 K9
SV650 Slipper Clutch badstart For Sale - SV's and SV related items 0 13-07-09 12:23 PM
Slipper clutch? Stu Bikes - Talk & Issues 71 17-11-06 08:04 AM
Can you get a slipper clutch for an SV? the oaf SV Talk, Tuning & Tweaking 44 04-04-06 06:45 AM
Slipper clutch Brand New Bikes - Talk & Issues 4 01-07-05 08:47 PM
Slipper Clutch Peter Henry Bikes - Talk & Issues 8 17-06-05 08:01 AM
