Old 17-11-10, 05:17 PM   #11
Bluepete
Bluepete's Avatar
Default Re: Jammed Ignition Help!
Take out the barrell, clean and replace. If there is grit in there, it'll only get worse and wear out the pins etc. I cleaned it out once or twice on my SV. As other said, Keep it lubed, ACF-50 seems to work well!
Pete
Old 17-11-10, 05:35 PM   #12
Sally
Wasn't frozen was it?
I used to get that if water got in and it was baltic outside...
Boiling water as per Owen said, or if you're out and about, lighter over the key to warm it up to melt the ice works a treat
Old 17-11-10, 05:36 PM   #13
maxinc
Originally Posted by danf1234 View Post
A bit late to go for a blast now too!
I would have been really ****ed if this would have spoiled my afternoon!
Old 17-11-10, 05:42 PM   #14
maxinc
That actually crossed my mind. 2 days ago I've done about 60 miles through London in constant rain and muddy spray. Judging by how dirty the bike and my gear is, I wouldn't be surprised if some of that carp got into the barrel and frozen in there.
Old 17-11-10, 06:30 PM   #15
danf1234
At least you weren't on your way to work mate.
Old 17-11-10, 06:36 PM   #16
maxinc
I was. I work from home.
Old 17-11-10, 06:37 PM   #17
danf1234
B-A_STard Unlucky. - Get it looked, at these things rarely vanish.
Old 18-11-10, 09:13 PM   #18
toxic
i also use air blaster, basically compressed air in a can, comes with a thin tube that fits in ignitions... not too much if ignition is wet, canned air is pretty cold.
Car jammed at max power today! Berlin Idle Banter 31 22-03-09 11:34 PM
Jammed Givi Box loupyn Bikes - Talk & Issues 8 05-02-09 12:47 PM
rear seat latch jammed kcowgergmm SV Talk, Tuning & Tweaking 0 01-09-07 01:40 AM
Gear lever jammed when stopped jb650 SV Talk, Tuning & Tweaking 14 21-01-07 04:25 PM
Gear Selector Jammed gman SV Talk, Tuning & Tweaking 9 10-12-05 07:13 PM
