Old 05-12-10, 11:55 PM   #11
toxic
Default Re: Cleaning Exhaust downpipes
i use those green pot scourers, non-metallic.
Old 06-12-10, 02:27 AM   #12
lammypie
+1 using a trafic film remover like muck off helps too but its def alot of work.
Old 21-03-11, 02:00 PM   #13
a1istair
OK.... I'm new to polishing but so far I have had a good level of success.
My strategy has been start with the most abrasive thing which will shift all the burned in and work finer. For my downpipes I had no chance with even the coarsest mop - but I used one of the wire brush drill attachments. Then my coarsest mop can easily remove the fine scratches left by that. In all, after only a few hours everything was looking pretty good. The only thing is that although I have removed all the burned in crap from the very top of the front downpipe it is quite pitted from the corrosion. Is there any chance I can smooth over these pits. And what would you suggest for the job? Obviosuly there some kind of limit before I polish the entire thickness of the pipe away.
Thanks,
a1istair
Old 21-03-11, 06:42 PM   #14
Lucas
halfords - heat proof spray
Old 06-10-11, 05:56 PM   #15
beabert
Bag was burnt on to my exhaust, so thought id sort it.
So happy the result, i thought id boast about it
Method: 240, 400, 600, 800, 1200 and rubbing compound. Just need to do the rest now.
Old 06-10-11, 07:18 PM   #16
Looks like you need the mid-section sorted as its tis a bit rusty
Old 06-10-11, 07:27 PM   #17
elbow grease soooooo yesterday....I am now a convert to Optiglanz from Hein Gericke.
I only have to use the elbow, lightly now, with autosol.....and no wet n dry!!!!
Old 06-10-11, 07:42 PM   #18
beabert
Ive seen it and heard varying reviews on it.
There was melted plastic and deep rust on this section, didnt think the stuff would shift it.
Old 06-10-11, 07:44 PM   #19
oh trust me....it gets rid of boot marks and Raptor rust If you can't get rid of Raptor rust, then it ain't worth buying! Ok so it took two attempts the first time I used it......thats how bad Raptors downpipes are. I've used it since after a good build up of shoite, and it got rid in a blink.
Even works on the crap on the rear downpipe, that has to be the worst one to try it on. Just have to be very careful about getting it anywhere other than the downpipes though, its naasty.
Cleaning downpipes? PuggledPrune SV Talk, Tuning & Tweaking 39 13-02-11 02:48 AM
Cleaning Exhaust DANINPLYMOUTH SV Talk, Tuning & Tweaking 0 12-09-09 08:25 PM
Have I got stock exhaust downpipes? UKStreetFighter SV Talk, Tuning & Tweaking 14 22-03-07 11:11 AM
Remus revolution high level exhaust and standard downpipes ianofbhills For Sale - SV's and SV related items 1 13-01-07 10:18 AM
Cleaning exhaust? FreshAL SV Talk, Tuning & Tweaking 4 17-01-06 05:28 PM
