Old 26-12-10, 05:41 PM   #11
Lozzo
Default Re: how do i keep cam timings when removing both heads
There is no guaranteeing that chain lands on same tooth of crank sprocket, or which side slack lands on.
I'd always recommend double checking the alignment after everything has been put back together, and then checking it again just to be sure. Then once you're happy it's right, turn the engine over slowly by hand to make sure there's no contact anywhere.
Better IMO to do it the slightly more long-handed way.
I like to cable tie the sprockets on because I'm dyscalculaic and easily lose count when finding the sixteenth pin. Having removeable sprockets makes this a damn sight easier
Pressed-on sprockets are nothing new?
I know that, seen a few pressed on type - doesn't make it any easier when you want to reassemble an engine though.
Old 26-12-10, 05:56 PM   #12
Less to get wrong if the sprockets have any adjustment and aren't dowelled in place.
Old 26-12-10, 06:16 PM   #13
Lozzo
99.9% of road bike cam spockets are not slotted and totally unadjustable. Most will only fit on the cam the one way too. The potential for getting it wrong is minimal, but there's no accounting for the numptiness of the inexperienced mechanic.
North Wales Rideout Route and Timings info Luckypants Rideouts & Meetings 0 22-09-08 09:22 PM
SV cam timings? ThEGr33k SV Talk, Tuning & Tweaking 14 22-08-08 04:24 AM
Glencoe massacre maps and timings northwind Rideouts & Meetings 7 14-08-08 10:56 PM
BBC Sport: McGuinness tops Superbike timings NewsBot News 0 13-05-08 08:50 PM
Smack heads and crack heads Razor Idle Banter 22 06-10-06 08:00 PM
