Old 16-01-11, 11:48 PM   #11
beabert
Default Re: Rear suspension adjustment mechanisms
Pretty much all have C spanner adjusters
The # is pounds per inch (spring rate)
TY
Old 16-01-11, 11:55 PM   #12
TSM
The Sick Man
TSM's Avatar
Originally Posted by beabert View Post
Are there rear shocks with easier ways to a adjust, than having to use a bloody C spanner. Im too light to leave it on full, the back wheel seams to leap of the ground at any givien oppotunity on max, which is rather fun, but not when its wet!
Adjusting the bloody thing after pillioning takes forvever as the hugger gets in the way.
Thank you.
light being how many kg?
if its leaping off the ground could be partly because you have it on full, stick it in the middle and wont be the best when pillioning or solo but not as bad
preload has diddly squat to do with how heavy you are, think of it as ride height adjustment
i like penske shocks for aftermarket units, not cheep but very good if you want to go to that expense, preload adjustment is easy (i use an allen key that fits the collar)
if you dont want to spend the money just stick it in the middle and live with it, actualy the SV c-spanner is easier to use than the stuff you get on kwak or suzuki gsxr shocks as that has a double collar and fine screw thread grrr
Old 17-01-11, 12:05 AM   #13
beabert
I'm just going buy feel, on max, is feels like a very hard ride with only me on. Im 67Kg. When at a lower setting pillioning, is bloody awful. I don't mine spending within reason, but my goal is really for ease of adjustment between two settings, so i think ill modify the tool.
Old 17-01-11, 12:51 AM   #14
barwel1992
your lucky i have to adjust mine with a long bar and a hammer as i cant get the c spanner any where near my collar
i have a gixer shock though
Old 18-01-11, 10:43 PM   #15
beabert
Yeah id just make it worse for myself i reckon lol.
Standard front suspension adjustment (newbie question) f0rmula SV Talk, Tuning & Tweaking 15 18-05-10 11:57 AM
C Spanner - Rear Preload Adjustment jessie SV Talk, Tuning & Tweaking 17 10-08-07 09:59 PM
OK, Front Suspension adjustment/ advice ccurts SV Talk, Tuning & Tweaking 35 02-05-07 07:30 AM
Naked Curvy with GSXR Suspension Adjustment Queries Ter SV Talk, Tuning & Tweaking 3 08-09-06 05:39 PM
Rear Brake Adjustment andyaikido SV Talk, Tuning & Tweaking 6 23-06-06 05:33 PM
