Old 03-02-11, 01:18 PM   #11
02 Sv650s Black
Default Re: Stebel Nautilus compact horn anyone?
I got the horn fitted lastnight. Same way as Maviczap. Only thing I have a question about is, what type of tubing should I use to connect the compressor to the horn,
Cbay suggests "Fuel Pipe".
Ended up with a really neat and tidy job.
Old 03-02-11, 07:14 PM   #12
Windscreen washer tube will be fine.
I used medical quality nebuliser tubing I just happened to have lying around
Old 03-02-11, 07:26 PM   #13
Originally Posted by MattCollins View Post
It is much easier to determine which wire does what with a multimeter or test light...
I see little point in the switching... Both horns on mine are always on with a circuit to delay the Stebel by ~500ms so that I can give it a short double tap on the electro-magnetic or hold it for loud and obnoxious. The only time that I would disconnect the stebel by pulling the earth is for roadworthy inspections (air horns are not allowed here).
Fine here though.
Just put relay coil in parallel with or instead of the stock horn, be sure to use a fuse on the hot from the battery.
Old 03-02-11, 09:57 PM   #14
02 Sv650s Black
Maviczap,
How did you fit the plastic horn piece to the fairing??
Cheers Mark
Old 04-02-11, 06:22 PM   #15
Originally Posted by 02 Sv650s Black View Post
Maviczap,
Cheers Mark
I know I used part of the indicator mount mounting screw for one part
But I can't remember how I attached it to the horn.
I'll have a look to remind me how I did it
Old 04-02-11, 08:17 PM   #16
02 Sv650s Black
Ive everything connected on the bike, wiring done, compressor fitted under pillion seat, windscreen washer tubing attached to the compressor threaded along the bike to the front and attached to the horn using a valve extender super glued to the horn. The only thing left to do is to secure the plastic horn part in position.
Thanks All for the advice this far.
Mark
Old 04-02-11, 09:05 PM   #17
Stonesie
Is there much of a delay using a length of tube?
Old 04-02-11, 09:08 PM   #18
none I noticed
Old 04-02-11, 09:19 PM   #19
02 Sv650s Black
No delay in the air reaching the horn, I thought there might be a delay also, so for a quick test I blew in the end of the washer pipe I was going to use and pointed it at my eye, and you can feel the air right away,
The hose was 2.4metres and I cut approx 700mm of it.
Hope this helps
Mark
Old 04-02-11, 09:25 PM   #20
Stig
This means the connection between the horn and relay would be 3ft or so. Depending where the horn was fitted.
3ft? Seriously?
Hope this helps
Mark
I'm not sure I would have used my eye as the test target.
STEBEL Nautilus compact air horns (new) markmoto For Sale - SV's and SV related items 12 14-12-11 09:03 PM
Stebel Nautilus Compact Horn xXBADGERXx SV Talk, Tuning & Tweaking 37 02-02-10 11:33 AM
Stebel Nautilus Horn appollo1 For Sale - Other Bikes and General biking items 2 20-10-09 07:52 PM
Stebel Compact Nautilus ibshort Stuff Wanted 1 21-05-09 01:10 PM
Stebel Nautilus Horn philthunder Ancillaries 2 06-03-05 09:57 AM
