Old 30-04-11, 10:06 AM   #11
Rob969
Default Re: What can I do to my `99 suspension?
If you want to stiffen up the rear a 04/05 zx10 rear shock is a good choice pretty much same length as a standard curvy and slightly stiffer spring. After 05 the zx10 springs are softer
Old 30-04-11, 03:58 PM   #12
MJC-DEV
MJC-DEV's Avatar
Just a small correction. The Nitron shock is not an emulsion type as there is a Teflon coated free piston which separates the Nitrogen and oil. Nitron are used (the more expensive versions) in racing, not sure how many ex Kawasaki shocks are raced?
MJC-DEV is offline   Reply With Quote
Old 02-05-11, 01:35 AM   #13
formula400
http://cgi.ebay.co.uk/Kawasaki-ZX10R...f#ht_532wt_905
is this what i need???
Old 02-05-11, 09:04 AM   #14
mikerj
Originally Posted by formula400 View Post
Length is good, spring rate is about 10% higher than standard which may be good depending on how heavy you are. However, the reservoir sticks up a quite a bit so the battery will be raised up significantly.
Old 03-05-11, 12:29 PM   #15
NTECUK
NTECUK's Avatar
Will a zx 7 damper and spring do the job. There are a few on flea bay .not to expensive.
Old 03-05-11, 02:18 PM   #16
That's a De Carbon piston design.
Better than emulsion as doesn't froth, but not as good as proper one with compression adjuster.
There is a guy running at front in Melville club with a kawa shock.
Suspension overhaul: MCT Suspension Stowmarket. Dicky Ticker Bikes - Talk & Issues 11 01-08-10 11:18 AM
Suspension set up nik_nunez Pennine Massive 4 24-02-10 08:44 PM
Suspension set up airbrush_assasin SV Talk, Tuning & Tweaking 10 04-06-09 08:22 AM
Suspension set up Mike2165 SV Talk, Tuning & Tweaking 2 15-09-07 02:03 PM
Suspension...? clanger SV Talk, Tuning & Tweaking 10 15-08-07 01:35 PM
