Old 24-05-11, 05:32 PM   #11
warmshed
Default Re: Servicing questions.
The oil you use should be 10W40 oil that conforms to the API SF or SG also it must have "JASO MA" on the specification, this ensures it is suitable for bikes with oil wet clutches such as the SV has. The make and whether is is Dyno, semi synthetic or synthetic are all contentious topics but any good make oil that has that specification wont do you engine any harm.
Ensure your antifreeze is stated as suitable for aluminum engines, not all are. Again its wise to use a good make. De-ionized water should also be used instead of tap water. I think distilled water is better but hard to find now.
Old 24-05-11, 06:35 PM   #12
fill oil until half way on the glass when the bikes up right then let the bike fully warm up, switch off wait 10 min then recheck level, top up if needed, dont put to much in other wise neutral will be a git to find about half way up the glass is fine (in between low and high mark)
No need to completely warm it.
Way I do it; fill it to F mark or little bit over, start up, check oil light has gone out within couple seconds. Wipe filter, rev it a bit and check for leakage, turn off. Wait couple of minutes and then recheck level and fill to F mark again.
Old 24-05-11, 06:37 PM   #13
Originally Posted by Drumming_Animal View Post
Open the oil filler cap when you drain the oil to allow air back in instead of the oil glugging out with the air going back in.
Bike has crank breathers anyway, it makes little difference IME.
Questions, questions - light bulbs and oil leaks. garynortheast SV Talk, Tuning & Tweaking 7 25-03-10 12:55 PM
Servicing Questions F1-D'TOX SV Talk, Tuning & Tweaking 20 20-02-10 10:26 AM
Lots of servicing questions Brettus SV Talk, Tuning & Tweaking 12 21-10-08 09:06 AM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
Lots of Questions - servicing, headlights, chain lube etc hoodlum SV Talk, Tuning & Tweaking 8 12-04-06 04:41 PM
