#11 | |
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#12 |
Im about to order one. Have you seen this? It's a diy one can anyone work out how its done?
http://www.ebay.co.uk/itm/UNIVERSAL-...item4d005b668f Ive also noticed this. http://www.ebay.co.uk/itm/CARBURETTO...item3a66f09478 Im quite happy not to buy anything thats o.t.t. as long as it does a basic job.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 17-04-12 at 12:05 PM. |
SV1000 throttle body balancing | Mark_h | SV Talk, Tuning & Tweaking | 9 | 23-05-10 11:25 AM |
Throttle body balancing | RingDing | SV Talk, Tuning & Tweaking | 22 | 29-04-09 02:12 PM |
Balancing Carbs/Throttle bodies | tomjones2 | Bikes - Talk & Issues | 6 | 06-07-07 10:07 AM |
Throttle body balancing | Caddy2000 | SV Talk, Tuning & Tweaking | 6 | 18-05-07 06:22 PM |
Throttle balancing - Friday night job? | BillyC | Soho Massive | 15 | 15-04-05 04:36 PM |
